Frustrating Monday Morning Session 1st August 2022
- Has thanked: 8415 times
- Been thanked: 8161 times
I wanted to concentrate on hydrogen alpha this morning....full disk and a closer view of AR13068, the main active region on the disk at this time.
After multiple attempts I finally got some images to share. The seeing wasn't great and the haze, wispy clouds and large patches of cumulus scuppered most of my attempts to make multi-pane mosaics for the FD and achieve a sharp close view image of the active region. I was out from 8:15 until 11:00 to capture these two images with everything else ending up in the bin.
First up is the Ha FD in mono and colour, taken on my Lunt 60 with a 2.5x PM and Basler acA2440-75 um:
20220801_Ha_FD_Mono by Stuart Green, on Flickr
20220801_Ha_FD_Colour by Stuart Green, on Flickr
Next is the closer view of AR13068 taken on my 150mm, double stacked, at f34 with a 2.5 x PM and Basler acA1920-155 um:
20220801_Ha_AR13068_Mono by Stuart Green, on Flickr
This was a bit soft and so I've probably over processed it to try to bring out the details, such as they are.
It's so frustrating when the conditions don't cooperate.
Thanks for looking.
Thanks for looking.
- Has thanked: 9143 times
- Been thanked: 6024 times
Re: Frustrating Monday Morning Session 1st August 2022
Maybe it took a while but you did very well Stu. Beautiful mosaic and closeup.
- rigel123
- Has thanked: 8309 times
- Been thanked: 8536 times
Thanks for the effort Stu, these came out nicely!
- Has thanked: 893 times
- Been thanked: 314 times
Very nice, Stu.
Call me Geoff.
- pedro
- Has thanked: 14 times
- Been thanked: 6573 times
These came out well Stu. I also imaged this morning with average seeing
Pedro Re'
- Has thanked: 20424 times
- Been thanked: 10242 times
Good results Stu, I was frustrated by the same conditions as you.
- Been thanked: 16689 times
These still look nice Stu. They also show how calm the Sun is. Despite a number of active regions none are exceptionally strong though AR13068 is certainly the best.
Thanks for sharing.
Thanks for sharing.
- Been thanked: 4786 times
- Has thanked: 17648 times
- Been thanked: 8787 times
Ah, I have found your frustrations of the day, they came out really nice though, even if it was a pain to get them and a very long session
Well the bonus was, at least you weren't at work
Many thanks for your kind comments, everyone.
- Has thanked: 6181 times
- Been thanked: 7142 times
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Fantastic images Stu.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Been thanked: 4340 times
Hi Stuart...
These turned out very well despite the interruptions and seeing. Well done
Many thanks Arne, Alun and Brian.
