Soft and shaky seeing made focusing pure guesswork.
50/1000 frames stacked. Last capture before the trees swallowed my sun.
PST Etalon sweet spot woes meant heavy cropping.
Stop laughing!
1.08.2022 AR13068
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
1.08.2022 AR13068
- Been thanked: 10489 times
Re: 1.08.2022 AR13068
That's ok Chris, don't be hard on yourself!
- Has thanked: 6305 times
- Been thanked: 7324 times
- Has thanked: 9319 times
- Been thanked: 6157 times
- Rusted
Thank you all for your kind words.
I am struggling with very uneven results from my PST etalon again.
Cropping the final image increases the "enlargement."
Which softens the results even more than the poor seeing manages on its own.
In the past I was able to compensate by rotating the Lunt BF1200.
Now this tactic seems not to have much effect.
I have a very clear and darker ring of detail.
With much brighter and softer areas just outside the ring
So I have to get the ROI under that ring.
Then crop hard to get rid of the unwanted areas.
It may be time to try aperture reduction.
Though I haven't had much luck with that in the past.
- Rusted
Thanks. I am using a PST etalon in a 150mm f/10 refractor. The little PST etalon was never intended for this duty.
Such modifications inevitably push the boundaries of what is theoretically possible. Albeit at a much lower price than a larger etalon.
Larger Lunt etalons, discussed here as successful donors, are suffering from many months of delays on delivery.
