A spectroheliogram of this morning in CaIIK3 light with POSS2 spectrograph with a 9 micron chrome slit on a quartz support (therefore highly transmissive of UV) that the friend Douglas Smith kindly gave to me. The result seems good. The conversion soft used was SLM
Fulvio
CaII K3 spectroheliogram of today
- fulvio.mete
- Been thanked: 84 times
- SunCaIIK0003 22-08-02 09-57 10 Img final.jpg (443.26 KiB) Viewed 1141 times
- Has thanked: 42 times
- Been thanked: 1487 times
Re: CaII K3 spectroheliogram of today
The ones you ordered from Lenox should work out about the same. As I mentioned before, because they are glass and not quartz, you will just have to be careful about thermal shocking them. The typical way to do that is with an ND filter somewhere in the system or a Herschel wedge.
The glass side is likely very robust but be a bit careful about rubbing the chrome side to clean it. The coating is typically only around 100nm.
Also, those look like they are highly reflective on both sides, so be a bit careful about where the reflected sunlight ends up. For sure, don't look into the telescope when it's pointed anywhere near the Sun.
The normal orientation is the glass side towards the Sun and the chrome side towards the SHG. You can usually tell which side is which if the look at the edge of the glass.
- Has thanked: 17667 times
- Been thanked: 8789 times
A wonderful image and great first light with the new slit.
- Bastelhannes
- Has thanked: 83 times
- Been thanked: 138 times
I can't wait to receive the slits form Douglas as well. I am printing parts for my new spectroheliograph currently...
