What has happened to GONG.nso.edu??
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi SCF,
What is wrong with GONG (gong.nso.edu).
Images are days or weeks old and sometimes only 1 site is showing an image, not always so good. Are they cost cutting ? To save on electricity, maybe going GREEN to save the planet ?
Thanks.
Magnus
Thanks.
Magnus
- Has thanked: 18105 times
- Been thanked: 8941 times
Re: What has happened to GONG.nso.edu??
I've noticed this too, I've guessed it is bad weather, most seem only a few hours out of date, however Udaipur is 29 days so something must be technically wrong with this one
- Has thanked: 17960 times
- Been thanked: 17106 times
Udaipur rarely works and Learmonth is certainly off band. Cerro Tololo was down for a while until very recently. I like Big Bear because it most closely resembles the visual view.
I usually use Big Bear or Cerro Tololo. Occasionally El Teide or Mauna Loa.
- Been thanked: 203 times
I'm with Kevin.
I tried to make contact with Learmonth but couldn't get through.
had to rely on older data to see what was happening to that recent big prom.
Lets hope it gets fixed very soon.
Gerard
Gerard
The Kanzelhohe Solar Observatory makes a good substitute for GONG when it's not clouded out. Since it's in Austria it's best set up for the time in Europe.
https://www.kso.ac.at/index_en.php
- Has thanked: 2501 times
- Been thanked: 4926 times
Thanks James for that heads up on the Kanzelhöhe Observatory website.
Solbrillante wrote: ↑Sat Aug 06, 2022 8:26 am Thanks James for that heads up on the Kanzelhöhe Observatory website.
You are welcome.
- Has thanked: 3329 times
- Been thanked: 1907 times
The Gong telescopes are each automatic in enclosures. And only maintained occasionally.
Cheers. Andrew.
Cheers. Andrew.
