Several nice prominances today!
APO 102 f/5 - Daystar Quark - Asi2600mm
Full disc 08/08/2022 - Quark+APO. A bunch of nice proms today!
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: Full disc 08/08/2022 - Quark+APO. A bunch of nice proms today!
Nice disk there!
- Has thanked: 3292 times
- Been thanked: 1887 times
At F5 its a bit short for imaging with a 4.2x Quark.
The filaments over the surface are less distinct than visually with my 90mm F6.7. And bright areas by the spots less obvious.
Proms are pretty much as I saw. Less dependent on tuning.
Cheers. Andrew.
Cheers. Andrew.
- Oh, I get it now!
- Has thanked: 51 times
- Been thanked: 94 times
Actually a Quark Combo + 3x telecentric barlow :-) Yes a bit short I can see that comparing to pictures from others... I might at least switch for a 4x or 5x barlow but then I wont have full disc...AndiesHandyHandies wrote: ↑Mon Aug 08, 2022 7:33 pm At F5 its a bit short for imaging with a 4.2x Quark.
However I was asking myself... If I put a diaphragm (I mean: a solid disc with a hole) in front of my refractor to get a smaller diameter, it would actually increase the F/D value. But would it help to get more contrast with the Quark?
- Been thanked: 16691 times
Very nice . I never can get the disc and proms together to look that good.
Yes it will, if you are using a 3x telecentric try a 50mm mask.
- Has thanked: 17667 times
- Been thanked: 8787 times
You certainly got a good prom fest good advice from Mark
