Imaging with a T300, now in CaK
- Has thanked: 714 times
- Been thanked: 496 times
Again, non favorable conditions this morning, with a cloud raising above the observatory (St Véran, French Alps) from ~8:30, then keep staying above our heads. It looks to be local meteorological phenomenon...
I could save one pic at ~8:00.
And then after patiently waiting, I could get an other one at 10:45 before stopping.
Alex
2022-08-05
Solar newton, D300, F6
Barlow x5
CaK Filter
ASI174
Stack of 70 and 30 pics
Alex
2022-08-05
Barlow x5
CaK Filter
ASI174
- Has thanked: 9144 times
- Been thanked: 6025 times
Re: Imaging with a T300, now in CaK
Superb images, Alex, specially considering the conditions ! The detail is incredible. Are we going to see some images from Fred and Christian ?
- Has thanked: 8415 times
- Been thanked: 8161 times
Superb images, Alex. Very nicely resolved penumbral features and granulation.
- Been thanked: 4786 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Very nice, what CaK filter are you using?
Thank you Franco.
Fred is testing different setups.
Christian, was imaging planets. He will probably move to solar soon.
CS
Alex
Thank you.
I'm using a modded Lunt; the original front filters are removed and I use a KLine instead as pre filter.
CS
Alex
Hi Alex,
What is the reason you prefer the K line filter vs Lunt's pre-filter?
Hi Valery,
I have more flux with the KLine as a prefilter (~70% transmission), compared to the front + middle filter of Lunt's CaK module.
There are spectro measurements of the Lunt prefilters in this forum.
CS
Alex
CS
Alex
- Has thanked: 6181 times
- Been thanked: 7142 times
- Been thanked: 16693 times
Nice!!
- Has thanked: 1087 times
- Been thanked: 1136 times
- Has thanked: 580 times
- Been thanked: 389 times
More explanation please.
Also, how did you cover the front of that Newt 300mm? I mean for CaK i don't know any frontal ERF, and a reflection that big sure needs one.
- Been thanked: 4340 times
Beautiful work Alex...thanks fro sharing
