As discussed here I lowered the diameter of my APO by adding a diaphragm in front, in order to increase the F/D of my setup and get better contrast (at the cost of less definition) with my Daystar Quark, while conserving the same scale to keep having the full disc in my sensor. It works quite well!
APO 70mm f/7.5 (original 102mm f/5.2) + UV/IR-cut filter + telecentric 3x + Daystar Quark combo + Zwo 2600mm
Full disk 10/08/22 with Quark and a tweak
- Been thanked: 16691 times
Re: Full disk 10/08/22 with Quark and a tweak
It worked very well!
- Has thanked: 1680 times
- Been thanked: 1163 times
Wonderfully done
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
- Been thanked: 4904 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Great result!
- Been thanked: 4786 times
