Sun full disk 20220616 (30 panel mosaic)
Sergio Alessandrelli
Oh, I get it now!
Oh, I get it now!
Has thanked: 118 times
Been thanked: 128 times
Post by Sergio Alessandrelli »
Hi to all
Another full disk from June. 30 panels and a bit of work and time to process the mosaic ;)
Full resolution and data on:
https://www.astrobin.com/v59aib/
https://www.astrobin.com/06whm8/
https://www.astrobin.com/3cr3q4/
https://www.astrobin.com/fk9oso/
Bye
[Group-1]-2022-06-16_T_11-03-24-0668_L_lapl5_ap8395_20220801172251_2022-06-16_T_11-22-18-0103_L_lapl5_ap11692_20220801172257-31-images_0000_Radius64_Limit3_5_Amount0_400_INV_AP_CL_RID.jpg
[Group-1]-2022-06-16_T_11-03-24-0668_L_lapl5_ap8395_20220801172251_2022-06-16_T_11-22-18-0103_L_lapl5_ap11692_20220801172257-31-images_0000_Radius64_Limit3_5_Amount0_400_INV_AP_CL_RID.jpg (4.79 MiB) Viewed 373 times
[Group-1]-2022-06-16_T_11-03-24-0668_L_lapl5_ap8395_20220801172251_2022-06-16_T_11-22-18-0103_L_lapl5_ap11692_20220801172257-31-images_0000_Radius64_Limit3_5_Amount0_400_CL_RID.jpg
[Group-1]-2022-06-16_T_11-03-24-0668_L_lapl5_ap8395_20220801172251_2022-06-16_T_11-22-18-0103_L_lapl5_ap11692_20220801172257-31-images_0000_Radius64_Limit3_5_Amount0_400_CL_RID.jpg (4.54 MiB) Viewed 373 times
Has thanked: 13090 times
Been thanked: 6445 times
Re: Sun full disk 20220616 (30 panel mosaic)
That's a nice disk Sergio!
pedro
Has thanked: 6 times
Been thanked: 4069 times
Post by pedro »
Nice FD image Sergio. I prefer the second image (chromosphere not inverted)
MAURITS
Has thanked: 1106 times
Been thanked: 2904 times
Post by MAURITS »
Nice to see Sergio.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
pupak
Has thanked: 926 times
Been thanked: 749 times
Post by pupak »
:bow Excelent work.
Radon86
Has thanked: 655 times
Been thanked: 581 times
Post by Radon86 »
Was this a solar spectrum filter or Lunt 150 solar scope.
Very detailed disc, and sharp.
Thanks
Magnus
Oh, I get it now!
Oh, I get it now!
I used a William Optics flt 132 and a SolarSpectrum SO1 filter
allhoest
Has thanked: 161 times
Been thanked: 336 times
Post by allhoest »
To make a 30 pieces mosaic, you must have pretty consistent etalon, pretty stable conditions and properly planning your individual captures in order to have no join issue.
Great job.
Alex
SassySun
Has thanked: 951 times
Been thanked: 368 times
Post by SassySun »
Beautiful mosaic Sergio!
~ Petrus ~
Flickr
LS60THa DS - LS80THa DSII - Calcium II K module 12mm - Lunt Herschel wedge 1.25" - Quark Chromosphere - Solarscout SS60-DS - Sol'Ex
Oh, I get it now!
Oh, I get it now!
allhoest wrote: Sat Aug 13, 2022 6:05 pm To make a 30 pieces mosaic, you must have pretty consistent etalon, pretty stable conditions and properly planning your individual captures in order to have no join issue.
Great job.
Alex
The SolarSpectrum etalon I have use a TEC stabilization but require flats because it's not so uniform. I cure the orientation of the camera to have the camera sensor parallel to the mount axes. Seeing is never so good but I make 2000 frame video for every frame and then I stak the best 10-15% of each.
Than i need to be luky, it's not easy to have an authomatic allignment of all the frames, sometimes I have to manually adjust the position, sometimes I have to use only some frames.
arnedanielsen
Has thanked: 3462 times
Been thanked: 3556 times
Post by arnedanielsen »
Good results Sergio!
Arne
Has thanked: 5763 times
Been thanked: 5341 times
Post by Carbon60 »
Nice results, Sergio. That's a lot of work!
Has thanked: 11547 times
Been thanked: 5853 times
Wow!! 30 panels!! well done!! :bow :hamster: I think someone in the Solar Software section asked the question whether you can automate the image capture as they keep getting lost, how do you manage to keep on track doing 30?
Oh, I get it now!
Oh, I get it now!
Montana wrote: Sun Aug 14, 2022 11:50 am Wow!! 30 panels!! well done!! :bow :hamster: I think someone in the Solar Software section asked the question whether you can automate the image capture as they keep getting lost, how do you manage to keep on track doing 30?
Thank you ;)
I don't use a specif software to automize the mosaic creation. Telescope mount is oriented toward the North: during the night I make a polar allignment of the telescope mount, marking on the floor the position of the tripod and than I unmount the telescope mount without changing anithing, just loosing the screew as needed to remove the head from the tripod. It maintain a good polar allignment for the day session and than I use the Hinode solar guide to track the sun.
Than after every video I manually move the mount to overlap each area for about 1/8 - 1/10 of the frame. For the mosaic creation I use AutoPano Pro 4.4 for Mac but it's no more maintained... It has a lot of option to change the exposition, the correction of distortion/vignettature and so on, but sometimes it can't find a correct set of allignment point to create the mosaic. If just one or two frames aren't recognized, I move manually the frames, otherwise I try to create sub mosaic and when possible merge them.
It's a bit of work but resolution is very high and I printed large posters with these mosaics ;)
Here my setup with the typical "spaghetti cabling" :lol:
