Barely C-Class
20220812092852Th HR V01 by Andrew Huskinson, on Flickr
https://www.kso.ac.at/index_en.php
https://solarmonitor.org/forecast.php?d ... 12®ion=
Upcoming solar weather to left of -90
https://stereo.gsfc.nasa.gov/beacon/
The far side
https://www.raben.com/maps/
90mm TS Triplet F6.7, 2" 40nm, T2 Baader Barlow, T2 energy dump & 28.5mm baffle,
9mm baffle on 4.2x, Chromo, 20mm baffle on 1.25" Helical focuser,
polariser on 40mm Celestron Symmetric with added 20mm field stop.
The prom at 10.00 looks like fine lace.
Cheers. Andrew
El Teide 12/08/2022
- Has thanked: 3326 times
- Been thanked: 1907 times
- Has thanked: 2501 times
- Been thanked: 4924 times
Re: El Teide 12/08/2022
Proms
11.15BST Light wind sunny with high haze
12.00 Rocket with 2 boosters ready to go
12.30 Faint spray / arch
2.30 Wide prom arching up with tracery under
2.45 Two little spikes
3.30 Double feed to toadstool cap leaning up.
Two feeds leaning up below.
Little thin spike leaning up below
4.15 Complax arch. Mobile crane leaning down holding up a 3 feed then 2 feed prom
6.00 Little pyramid
6.15 Open pyramid (2x larger) and a faint one to the right.
8.30 5.00 Gong under large spot.
Dumpy pyramid two holes at the bottom
Above a small pyramid, with 2 small holes
Eyebolt with 2 extensions underneath at the top.
11.15 Small spray, tiny pyramid. Classic small pyramid.
Spiricule layer visible.
Cheers. Andrew.
6.00 Little pyramid
Cheers. Andrew.
Cerro Tololo B-Class flare 12/08/2022
Been trying to compare my visual view of the surface with FD images on the forum. Or elsewhere but no luck.
I have picked up the flare bottom left on here
20220812125312Ch HR V01 by Andrew Huskinson, on Flickr
Generally I think I can see what can be imaged, without excessive stretching burning out details.
I have a bit of contrast control with the polariser.
Must try some small area images with my donated CCD next.
Cheers. Andrew.
Cheers. Andrew.
- Has thanked: 20938 times
- Been thanked: 10586 times
Thanks for the report Andrew.
