good evening to all,
the sunshine of the day when I found some time to brave the heat wave and take the portrait !
At the fs60 with his sm40 double stack, BF10, glasspath x1.7 and zwo178mm around 1:40 pm UT
cordially
stephane
sun halpha of August 12
- stef41
- Has thanked: 120 times
- Been thanked: 1476 times
- Has thanked: 17458 times
- Been thanked: 16560 times
Re: sun halpha of August 12
Beautiful discs Stephane!! You have faithfully captured what I saw visually today if not a bit more!
What a beautiful serene rural observing site. Absolutely gorgeous! I bet the night skies look good there. Are those grapevines along the fence?
- Has thanked: 20240 times
- Been thanked: 10116 times
Hot disks there Stephane!
- Has thanked: 9082 times
- Been thanked: 5977 times
- Has thanked: 2407 times
- Been thanked: 4737 times
- stef41
thanks to you
Yes, these are indeed vines along the fence. Normally I will have grapes to taste in September!
cordially
stéphane
I live in the French cereal region ("la Beauce"), the horizon is clear and if we move away from the cities (as it is my case ) : no more street lamps and a milky way which goes from one horizon to the other. The only small concern is during the period of the harvests where the atmosphere becomes less transparentDeepSolar64 wrote: ↑Fri Aug 12, 2022 11:52 pm
cordially
stéphane
It’s a beautiful place Stephane. How hot has it been?
- Has thanked: 6161 times
- Been thanked: 7097 times
