Saturday Sun 13th August 2022
- Has thanked: 8497 times
- Been thanked: 8229 times
A few from this morning across the spectrum in Ha, CaK and 'WL'. A beautiful day, but too hot to be out for too long and the seeing conditions were getting worse by the minute. The images are not in chronological order.
First up are my 'WL' images, taken at 430 nm. These are 4 pane mosaics on a Tecnosky 125 mm f7.8 with a 90 mm mask. A Lacerta solar wedge was used for these shots fitted with a suitable filter. The camera was a Basler acA2440-75 um.
20220813_430_FD_Mono by Stuart Green, on Flickr
20220813_430_FD_Colour by Stuart Green, on Flickr
Next up are a few images in CaK (FD and closer views of the main sunspots) all were taken on the same scope/camera with a Lunt CaK B1800 module fitted with an additional Omega filter. The FD is a 4 pane mosaic and the closer views were imaged with a 2.7x Barlow.
20220813_CaK_FD_Mono by Stuart Green, on Flickr
20220813_CaK_FD_colour by Stuart Green, on Flickr
Unnumbered active region (I assume this one will be AR13081). The newest active region on the eastern limb.
20220813_CaK_AR13081_Mono by Stuart Green, on Flickr
20220813_CaK_AR13081_Colour by Stuart Green, on Flickr
AR13076
20220813_CaK_AR13076_Mono by Stuart Green, on Flickr
20220813_CaK_AR13076_colourpng by Stuart Green, on Flickr
Active regions 13071, 13077, 13074 & 13079 towards the western limb
20220813_CaK_AR13071_77_74_79_Mono by Stuart Green, on Flickr
20220813_CaK_AR13071_77_74_79_Colour by Stuart Green, on Flickr
Calcium proms
20220813_Cak_Prom1 by Stuart Green, on Flickr
20220813_Cak_Prom2 by Stuart Green, on Flickr
Over to the red end of the spectrum in hydrogen alpha:
Full disks in mono and colour, imaged and processed as nine pane mosaics.
20220813_Ha_FD_Mono by Stuart Green, on Flickr
20220813_Ha_FD_colour by Stuart Green, on Flickr
Finally AR13074 in Ha using my single stacked 250 mm RC telescope fitted with a Basler acA1920-155 um camera and 2.5x PM. No excuses...but the seeing really wasn't up to it with the growing heat of the morning (this was taken first thing, as soon as the rising Sun hit the scope). Consequently I've processed the life out of the original image to try to make something half decent. These super warm days (for us Brits) don't really lend themselves to large aperture hi-res imaging. Anyhow, here's the result.....
20220813_Ha_RCT_AR13074 by Stuart Green, on Flickr
Trying to cool off indoors, processing and uploading these images....but still too warm. I need ice cream
Thanks for looking.
AR13076
Calcium proms
Thanks for looking.
- Has thanked: 2445 times
- Been thanked: 4845 times
- Been thanked: 4933 times
- Has thanked: 17713 times
- Been thanked: 16853 times
Re: Saturday Sun 13th August 2022
Stu,
This is a nice collection of three-light images. You have captured all well. I am especially impressed with the CaK proms. Beautiful!!
- Been thanked: 4389 times
Superb series of images Stuart...nicely done
- Has thanked: 20620 times
- Been thanked: 10367 times
A great run of images Stu!
- Has thanked: 6235 times
- Been thanked: 7215 times
Many thanks, everyone. I really appreciate your feedback.
- nicspenceryork
- Has thanked: 5998 times
- Been thanked: 1305 times
Many thanks, Nic. Much appreciated.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Stuart,
Excellent work and imaging !
How did you cope with those temperatures ?
I was too scared of the high temps and stayed indoors !
DId you manage to measure the seeing quality ? I think in high heat, the seeing may not be too good, especially if you imaging over houses or concrete ??
Magnus
Magnus
- Has thanked: 9230 times
- Been thanked: 6091 times
An excellent and complete set, Stu: looks like you had a great session.
Many thanks, Magnus and Franco.
Hi Magnus,Radon86 wrote: ↑Mon Aug 15, 2022 4:56 pm Hi Stuart,
Magnus
I image early in the morning to avoid the heat. This provides the best seeing which rapidly deteriorates as the roofs and driveways around me warm in the summer Sun. It’s a small window of opportunity because much of my view towards the east is blocked by my neighbours’ house and trees.
- Has thanked: 17816 times
- Been thanked: 8855 times
Oh my!! what a lovely collection, I do like the CaK proms
Many thanks, Alexandra
