Various active regions and prominences taken today 2022.08.14
MichaelTeoh
Has thanked: 289 times
Been thanked: 584 times
Post by MichaelTeoh »
Only managed to complete the h-alpha session before it became cloudy. Seeing condition was average. Transparency was not good, as there were thin clouds all over the sky.
ImageAR3074_79_20220814_0328_H3x by Michael Teoh, on Flickr
ImageAR3074_20220814_0307_H3x by Michael Teoh, on Flickr
ImageAR3076_20220814_0327_H3x by Michael Teoh, on Flickr
ImageAR3078_20220814_0313_H3x by Michael Teoh, on Flickr
ImageAR3078_20220814_0330_H3x by Michael Teoh, on Flickr
ImageAR3079_20220814_0305_H3x by Michael Teoh, on Flickr
ImageAR3081_20220814_0304_H3x by Michael Teoh, on Flickr
ImageProminence_20220814_0318_H3x by Michael Teoh, on Flickr
ImageProminence_20220814_0321_H3x by Michael Teoh, on Flickr
Michael Teoh, Penang, Malaysia
APM-TMB 228/2050, Lunt LS152
https://www.flickr.com/photos/michael_teoh
Has thanked: 20738 times
Been thanked: 10437 times
Re: Various active regions and prominences taken today 2022.08.14
Nice shots Michael!
Are your images you are sharpening in 16bit?
MichaelTeoh
Thanks Mark.
The capture was in 8 bit. After stacking with AS!3, it become 16 bit.
Has thanked: 17925 times
Been thanked: 8891 times
What a super set :bow :hamster:
MichaelTeoh
Thanks Alexandra.
Btw, you mentioned in another post that Registax is terrible for solar and lunar. I've heard about ImPPG for quite some time but had never really tried it. Inspired by your comment, I reprocessed some of these images above using ImPPG, as well as a few of my best images from the past, but to my disappointment, they didn't end up much better compared to the result I get with Registax. The only obvious differences I see on the ImPPG results are that they have better dynamic range, and the contrast is slightly different.
Have you played about with the number of iterations and unsharp mask?
MichaelTeoh
Unsharp mask yes, iteration no. I follow a few tutorials I found on Youtube, they don't mention adjusting iteration, only the sigma and amount.
Here is one of the file (after stack), feel free to try your way of processing, then I can see what could be achieved.
I had a very quick flick before bed
ImPPG
2022-08-14-0327_0-MT-L_F500 a.jpg (91.4 KiB) Viewed 662 times
MichaelTeoh
Thanks Alexandra.
I see a lot of people producing images that look like yours, probably due to the same processing method being used. But personally they look a bit too soft to my liking.
Anyway, how do you determine the four parameters, i.e. the sigma for the L-R deconvolution, the iterations (suggested value between 30-70), and the unsharp marking's sigma and value?
Thanks.
Dennis
Has thanked: 3053 times
Been thanked: 2152 times
Post by Dennis »
Hi, here is my quick take on it close to Alexandras. I guess everyone has his own style and taste. I prefer imppg and photoshop for this.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Has thanked: 9292 times
Been thanked: 6128 times
Post by ffellah »
Very nice results in the conditions
MichaelTeoh
Thanks Franco. Surprisingly so.
There are no hard lines on the Sun, it is soft plasma. Plasma cannot have a hard line due to its nature, but it can have structure. If you sharpen too much all you are doing is presenting image artefacts and not solar structure. If you have perfect seeing conditions or larger aperture you will see more structure in the plasma. But you cannot create structure by over sharpening / artefacts.
However, everyone has their own personal taste, but I prefer to sharpen the structure only, once I reach the point where it becomes artefact I stop. You have to play around with the sliders until you are happy, there are no fast rules and everyone will go about this in their own way. My goal is to try and keep it a true representation (the scientist in me) to what I saw. I watch the video closely, then try to match the video and times of perfect seeing that my eyes see to the final image. If what you see is what you present then that is fine :) equally, if you present something which is nothing like what you saw then that is fine too, it is personal taste and only you know want you want to achieve.
Here is my take on it (just in ImPPG). Make sure you check 'cropped' in AS3, it gets rid of the artefacts on the edges.
MichaelTeoh
I always use "Expand" and crop afterwards, because I keep my images in 2:3 ratio, sometimes I will need some parts to fulfill that, which will otherwise be cropped during stacking.
pedro
Has thanked: 14 times
Been thanked: 6684 times
Post by pedro »
Here is mine (IMPPG & PS CS6)
Can you tells us more on the APM-TMB 228/2050
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
Hi Michael, here's my take (ImPPG only):
ImPPG settings file:
[The extension xml has been deactivated and can no longer be displayed.]
My software:
My images
MichaelTeoh
pedro wrote: Fri Aug 19, 2022 7:59 am Can you tells us more on the APM-TMB 228/2050
Hi Pedro, attached below is a picture of the scope and the setup. I use it without an ERF (can't afford one).
Post by ffellah »
Nice setup, Michael. Plenty of space, nice installation.
MichaelTeoh
Hi Franco, it's the roof top of a 8-story building, so the space was not much of a concern when they build the observatory.
pedro
Post by pedro »
Thanks for the setup images Michael. It is a fantastic setup - Paramount ME + OTA
I teached a few astrophotography courses in Malaysia a few years ago | National Space Agency, Malasia (Langkawi National Observatory)
CCD Imaging Course (Malasia, 2012) - http://astrosurf.com/re/ccd_imaging_cou ... _2012.html
CCD Imaging Course (Malasia, 2008) - http://astrosurf.com/re/ccd_imaging_cou ... _2008.html
CCD Imaging Course (Malasia, 2007) - http://astrosurf.com/re/ccd_imaging_cou ... _2007.html
CCD Imaging Course (Malasia, 2006) - http://astrosurf.com/re/ccd_imaging_cou ... _2006.html
best regards
MichaelTeoh
I see a few friends in the photos of the courses :)
The scopes are working relatively well after 11 years. The only major issue was replacing the board in the Paramount ME in 2014. Then starting a few months ago, the joystick won't home properly.
pedro
Post by pedro »
Thanks for your reply Michael. I also have experienced a few issues with my paramounts ME. I had to replace the boards several times. Fortunately I have a friend that was able to repair the boards.
Imageparamount_ME_2_board_20210415-019 by Pedro Re', on Flickr
Imageparamount_ME_2_board_20210415-003 by Pedro Re', on Flickr
Imageparamount_ME_2_board_20210415_mosaic by Pedro Re', on Flickr
MichaelTeoh
Glad to know you can get the boards repaired. Hopefully it won't happen again.
