I have attempted Full disc in a single exposure frame with a Quark chromosphere and applied a focal reducer, I think the total reduction is about 0.4x, making the Focal ratio about (F6 telescope x 4.2 (Quark) x 0.4)=Focal ratio 9.6. Camera : ASI 174mm (pixel size 5.86 microns).
I looked at Arne Full disc with his ASI 178mm and Coronado 60mm telescope and wondered if I would get a better sampling sensor with 2.4micron pixels with the ASI 178mm (I think ASI 183mm has same pixel size, larger sensor, more expensive x2).
Would anyone agree ?
I asked First Light Optics, the camera is not available yet, may take 1-2 weeks.
Is it worth it to buy the ASI 178mm. I could also use it for Planetary imaging with my F5 reflector.
Many thanks.
Magnus
ASI 178mm camera for FD Quark chromo (Reducer)
- Has thanked: 20813 times
- Been thanked: 10484 times
Re: ASI 178mm camera for FD Quark chromo (Reducer)
Hi Magnus.
Have you measured the reduction factor or just assuming is 0.4
Are you sure it's going to give a fd on the 178? I think you will need a 2 pane mosaic.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hi Mark,marktownley wrote: ↑Mon Aug 15, 2022 6:23 pm Hi Magnus.
Yes I agree it will be a 2 pane mosaic. The ASI 183mm would be larger and do a full disc more easily.
I think I estimated the focal reduction I was getting for my reduction for FD on the ASI 174mm was about 0.4 (I can change this by adjusting the sensor-focal reducer distance).
Thanks Mark
