Since conditions were somewhat uncomfortable this session, I had a short session sitting in the shade of my house most of the time while my LS60 basked in the sunlight. I had not planned this session but I noticed a curious, ring shaped AR on the western limb and that prodded me to set up. I used only my LS60 for all these images today but, if conditions are better next day, I'll make use of my larger optics and hopefully both the large filament and ring structure will still be there. The LS60MT was double stacked with a front mounted LS60F for these images with a 2.3X Barlow on an ASI1600 camera
Lou
A variety from Aug 20
- Been thanked: 1735 times
- Been thanked: 16691 times
Re: A variety from Aug 20
Very nice detail!! The inverted images really show nice relief. Nice depth! That filament looks circular with the walls of a great circular plasma crater or walled plain. Is that an elongated central peak I see!?? ;-)
- Has thanked: 8415 times
- Been thanked: 8161 times
Really nice set of images, Lou.
- Has thanked: 17666 times
- Been thanked: 8787 times
- rigel123
- Has thanked: 8309 times
- Been thanked: 8537 times
Great shots Lou and that is a fascinating circular filament.
- Has thanked: 20424 times
- Been thanked: 10243 times
Lovely shots there Lou!
- Been thanked: 4340 times
Superb shots Lou...well done
That circular filament caught my attention too...I don't think I've seen the likes of that before.
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Lou,
Superb imaging job here! There is a 3D effect I see. Any chance of you showing the Tone curve adjustment you did in ImPPG ? I find it a bit tricky still to do the inverted image format.
Thanks!
Magnus
Thanks!
Magnus
