Remote pressure WiFi controler for LUNT LS60-150
- Has thanked: 4379 times
- Been thanked: 3977 times
First prototype is ready for testing. Now Sun missing only.
Manuál, USB or WiFi control via HTTP. ASCOM driver coming soon.
Pressure 0 - 30 PSI +- 0.1 PSI. Store and restore target value.
- tp2.jpg (355.13 KiB) Viewed 2045 times
- tp1.jpg (475.41 KiB) Viewed 2045 times
- Has thanked: 20828 times
- Been thanked: 10499 times
Re: Remote pressure WiFi controler for LUNT LS60-150
That's clever! Keep us updated how you get on!
The first test of the regulator turned out great. Fine-tuning the pressure with visual control on a large monitor is the ideal solution. The optimal pressure is maintained with an accuracy of 0.1 PSI and subsequently stored in the controller's memory. The next time I observe, I just hit the Restore button and I'm right in the H-alpha band. My experience is that the etalons will not hold the pressure because the seal is not good, so they need to be adjusted often. The regulator solves this to my complete satisfaction. The week spent developing the regulator paid off handsomely.
Nice engineering solutions!
- The Sun?
- Has thanked: 4 times
- Been thanked: 5 times
Nice work!
I'm interested
to see how you connect the tuner to your remote system.
I'm interested
I have a NUC on mount, that's why I use USB. The second option is control via WiFi. During the test, I used manual control with buttons on the panel and a 10m pressure hose to the etalon.
- pumpa3.jpg (922.95 KiB) Viewed 1947 times
- pumpa2.jpg (1.19 MiB) Viewed 1947 times
- pumpa1.jpg (604.26 KiB) Viewed 1947 times
- OlegLviv
- Has thanked: 918 times
- Been thanked: 946 times
Nice! Do you have on photo F7 or F6 telescope? Thanks!
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
It is Lunt LS80 - F7.
- Ivan
- Has thanked: 3489 times
- Been thanked: 2267 times
Hello,
Great job, a very interesting and necessary project! I also often noticed that during a long session the strip moves out (temperature or poor tightness).
Can you describe the pneumatic circuit in more detail? How did you manage to avoid air strikes? using a receiver and valve system? But if the engine is pumping the receiver on and off, then how is the pressure regulated in a closed system (when the engine is turned off and the receiver is full)?
Ivan
Ivan
The most important thing is the sufficient volume of the air reservoir. With sufficient size, pressure changes are gradual and regulation is +- 0.1PSI. However, even changes of +-0.5 PSI are not detectable by eye.
The system is simple. The pump increases the pressure and the discharge valve decreases it. A quality Honeywell 0-30 PSI pressure sensor with an error below 1% is important.
- Bastelhannes
- Has thanked: 83 times
- Been thanked: 138 times
I love the idea. I am trying to make a similar solution for the Sundancer2, but I can't program.
Please keep us updated. Maybe we can create a commercial solution (of course with you on board)?
No problem.
- Been thanked: 2725 times
Great job !!
