First Light Daystar Quark Chromosphere
- Has thanked: 986 times
- Been thanked: 349 times
Roughly processed; AS3 & Imppg. More practice needed! I've not had this much detail on my Lunt LS60tha!
Tuned on setting I received the unit.
No flats applied
William Optics 102GT + diagonal + uv/ir cut + tilt adapter + ZWO 174mm (cool)
Tuning at around 9 minutes from switch on.
A few images -
No flats applied
A few images -
Call me Geoff.
- Has thanked: 20938 times
- Been thanked: 10587 times
Re: First Light Daystar Quark Chromosphere
Promising start Geoff!
My advice at this stage; try images around either side of the dial setting you worked on, look for even illumination and contrast across the field of view with most detail. It don't look far off in the images above.
Try ticking 'crop' in AS3 when you stack, it will get rid of the jaggedy edges to the image.
- Has thanked: 2501 times
- Been thanked: 4924 times
- Has thanked: 1898 times
- Been thanked: 1347 times
Appears you have a decent copy of a quark.
I am looking forward to seeing more.....
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Welcome to the Quark club Geoff. When you get a chance you should should do a series of test captures on the same area of the Sun, retuning your Quark for each exposure. Then stitch them together for a comparison.
Here's a series of captures I took last week, these are raw stacks each with exactly the same capture settings ,with no flats or post processing. It will give a good indication of the optimum settings for your Quark.
H-alpha_123130_lapl5_ap9402 by Martin Symonds, on Flickr
- Has thanked: 141 times
- Been thanked: 240 times
The Quark does seem pretty evenly illuminated.
I find my best tuning to be -5 (negative 5). I think several of us do as well.
While I'm recovering next week I'm hoping I have enough brain cells to put together my version of a processing tutorial to add to the number of other excellent choices out there.
In fact, I would not mind taking a stab at processing those files myself to see if it is capture or processing. How big are your AVIs? Maybe I can dropbox them...
Jack
Jack
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
Thanks guys. I'm fairly chuffed with what I managed at a starter. I fully intend checking each setting and I'm slightly assured that it took only 9 minutes to come upto temperature. An earlier attempt powering through a Pegasus Ultimate didn't yield a green light after 20 minutes - strangely!
After a brilliant morning of sunshine, yesterday, Friday has dawned cloudy! Och weel that's weather.
@jack - the above files were each around 5GB (1000frames). I also took 4 in sequence as the Quark warmed up, they are around 3GB (500frames).
Another story to this - I purchased a 102 refractor, f11, specifically for this Quark - sadly its focus comes in at 150mm - Quark, tilt, zwo174mm are around 170mm length! There's an option to remove the lower 120mm of the tube, but the guy who fitted it at the factory over torqued one of the three retaining screws and stripped its hex drive.
Call me Geoff.
Pick up a stripped screw head remover for about a fiver, that will shift it.Alto wrote: ↑Fri Sep 02, 2022 6:11 am Another story to this - I purchased a 102 refractor, f11, specifically for this Quark - sadly its focus comes in at 150mm - Quark, tilt, zwo174mm are around 170mm length! There's an option to remove the lower 120mm of the tube, but the guy who fitted it at the factory over torqued one of the three retaining screws and stripped its hex drive.
- Has thanked: 18090 times
- Been thanked: 8934 times
Thanks Mark. That's a new one on me. I've previously just drilled out the screw head - but that was in wood and less delicate! Am a little annoyed the shop hasn't gotten back to me.marktownley wrote: ↑Fri Sep 02, 2022 6:42 amPick up a stripped screw head remover for about a fiver, that will shift it.Alto wrote: ↑Fri Sep 02, 2022 6:11 am Another story to this - I purchased a 102 refractor, f11, specifically for this Quark - sadly its focus comes in at 150mm - Quark, tilt, zwo174mm are around 170mm length! There's an option to remove the lower 120mm of the tube, but the guy who fitted it at the factory over torqued one of the three retaining screws and stripped its hex drive.
Call me Geoff.
If you like, PM me and send me your AS3 tifs. I’d like to experiment.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
https://www.amazon.co.uk/ENGINEER-DBZ-2 ... NrPXRydWU=
Something like that should work. I only had a quick look so you might find cheaper alternatives.
Thanks Mark - there's a couple of youtube videos that have offered some ideas to try.
Call me Geoff.
Finally I've managed to coax the screw loose. There was very little in the head.
A bradawl pushed gently in had enough purchase to allow grip and removal!
Phew.
It's annoying I've seen little of the sun since this first light - now I have the scope fixed we're away for a couple of weeks.
Sun'll still be there in October, won't it .........
Is there a minimum temperature for use of the Quark?
Phew.
Call me Geoff.
