Skywatcher Heliofind - The view into the inside.
Bastelhannes
Has thanked: 83 times
Been thanked: 138 times
Post by Bastelhannes »
For an idea, a Skywatcher Heliofind mount is disassembled to see if it can be modified for other purposes:
What is needed:
  • Phillips screwdriver small
    Phillips screwdriver normal
    Allen key size 1.5
    Cutter knife
Attention: Before you start: Parts will be destroyed during disassembly!
Disassembly of the Heliofind:
01 Kopie.jpeg (71.63 KiB) Viewed 1141 times
The four small cross screws must be loosened.
02 Kopie.jpeg (101.11 KiB) Viewed 1141 times
The other two cross screws in the recesses as well.
03 Kopie.jpeg (112.53 KiB) Viewed 1141 times
The cover must be removed. Unfortunately, this is not non-destructive.
04 Kopie.jpeg (122.21 KiB) Viewed 1141 times
You can see the remains of the adhesive pad. The four Phillips screws are loosened.
05 Kopie.jpeg (135.84 KiB) Viewed 1141 times
The two grub screws are loosened and the ring is unscrewed.
Then the axle can be pressed in carefully. Unfortunately, the cover on the other side cannot be loosened otherwise.
06 Kopie.jpeg (75.86 KiB) Viewed 1141 times
This is how the inner workings look like.
The board is a modified version of the AZ-GTI, without WIFI and with other connectors.
07 Kopie.jpeg (120.64 KiB) Viewed 1141 times
There is also this cover that can be pulled off. Unfortunately, this design did not help in opening the mount.
I am not sure, if reports like this are wanted. If you think it's okay I will post more of these things here, when I disassemble or destroy more sun related parts...
Bastelhannes / Karsten
