2022-09-05 - Big filament around AR13092_93
An archive of all the best images Solar Chat has to offer!
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Quick lunchtime solar session to see if I could capture the large filament. Temperatures outside just over 30 degrees (Celsius), so quickly out and back in again (like I mentioned before, I can't handle the heat).
The entire thing didn't fit in a single frame, you I ended up doing a 4-panel mosaic. In hindsight, it would probably have fitted in two as well if I used less overlap. But I got the image; that's what matters :)
Setup: 100ED, Quark Chromosphere, 35nm Baader H-Alpha, ASI174
Thanks for looking.
Jochen Maes
Belgium
https://www.jochenmaes.com
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Re: 2022-09-05 - Big filament around AR13092_93
Post by MAURITS »
That's a really nice one Jochen.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17894 times
Been thanked: 8887 times
That's a super image and beautifully put together. I like the little bright tip to the tail by the main spot, it almost looks like the tip of a scorpion tail :bow :hamster:
