El Tiede 10.20 BST
20220905092452Th HR V01 by Andrew Huskinson, on Flickr
90mm TS Triplet F6.7, 2" 40nm, T2 Baader Prism, Energy dump & 20mm baffle in T2 Pass-28.5mm,
9mm baffle on 4.2x, Chromo, 20mm baffle on 1.25" Helical focuser,
20mm baffle on polariser on 32mm Meade 4000 with added 20mm field stop.
10.10 BST Sunny spells. Still. Clear.
Over next doors bungalow and a bit wobbly.
Spicules visible.
Under 8.00 Spot with a plage above.
8.00 Little bright spike.
Thin Filament - Backward J short end starting under spot. Plages to top right short end. A gap and then plages sticking out after the gap.
3.30 Flat oval near limb.3 spots on inner edge, two small plages inside, thin filament on outer edge.
3.15. Over the active region two stubby proms.
1.30 Little spike
12.30 Complex hedge with 4 components
11.30 Hollow prom with wings.
9.15 to 8.45 Fine complex with leaning down proms.
10.30 BST
Cheers. Andrew.
Observations 05/09/2022
- Has thanked: 3292 times
- Been thanked: 1887 times
- Has thanked: 20426 times
- Been thanked: 10243 times
Re: Observations 05/09/2022
Lots of nice activity Andrew, sounds like you got a nice view in.
- Been thanked: 16693 times
I am glad you got a view in. I had heavy rain here in WNC.
- Been thanked: 4786 times
- Has thanked: 17667 times
- Been thanked: 8788 times
Great report Andrew, I'm glad you managed to get a session in before the cloud and rain
