Sept 8th, 2022
- Has thanked: 288 times
- Been thanked: 244 times
Sept 8th, 2022
Hi All,
Just wanted to share a few captures from today. This was my first attempt at imaging with the ASI174MM. I must say, it was very nice to have integration with the mount via firecapture and feature tracking. There are a few alignment artifacts though that may be related. These are taken with a Quark+Lunt 40mm double stack in a 127mm/1200 doublet with a 2-inch 35nm H-alpha filter as ERF. Hope you enjoy.
Best,
Derek
B&W:
Colorized:
Best,
Derek
B&W:
Colorized:
- rigel123
- Has thanked: 8560 times
- Been thanked: 8795 times
Re: Sept 8th, 2022
Those are beauties Derek!
- Has thanked: 17829 times
- Been thanked: 16971 times
Re: Sept 8th, 2022
Derek,
WoW!! These are beautiful! Very nice. I think the last one is my fav.
- Has thanked: 9306 times
- Been thanked: 6140 times
- Arrakis97
- Has thanked: 350 times
- Been thanked: 306 times
Re: Sept 8th, 2022
Wonderfull detail Derek; I especially like those in high contrast colorOak wrote: ↑Fri Sep 09, 2022 1:45 am Hi All,
Derek
Thx for sharing
Carlo
- Been thanked: 2725 times
Re: Sept 8th, 2022
Excellent Derek, and very nicely processed !
Have you tried the "cropped" option in AS3 ?
- BGazing
- Has thanked: 289 times
- Been thanked: 352 times
Re: Sept 8th, 2022
Fantastic! You could have cropped the second and the third one, as Christian suggested.
What are your color settings? I like them very much.
Lunt 80MT DS, 533/1600/462
- Has thanked: 20778 times
- Been thanked: 10453 times
Re: Sept 8th, 2022
A very nice set of images there!
Re: Sept 8th, 2022
Thanks Christian. These are cropped because my polar alignment was not great. Not sure what is causing the horizontal line in the bottom left. I don't see it in the first image where I did not use guiding but do see it in most others. I will try to reprocess a few and see if anything changes.christian viladrich wrote: ↑Sat Sep 10, 2022 6:52 am Excellent Derek, and very nicely processed !
- Has thanked: 17970 times
- Been thanked: 8903 times
Re: Sept 8th, 2022
I was able to fix the artifact. There is a setting in the autostakkert "advanced" menu called "Detect abrupt horizontal and vertical artifacts" that did the trick. Now, I am quite happy with these.Oak wrote: ↑Sat Sep 10, 2022 11:14 amThanks Christian. These are cropped because my polar alignment was not great. Not sure what is causing the horizontal line in the bottom left. I don't see it in the first image where I did not use guiding but do see it in most others. I will try to reprocess a few and see if anything changes.christian viladrich wrote: ↑Sat Sep 10, 2022 6:52 am Excellent Derek, and very nicely processed !
-Derek
Reprocessed in B&W:
Reprocessed and colorized:
- Has thanked: 6276 times
- Been thanked: 7302 times
