AP155 and LS80 DSII
- Has thanked: 175 times
- Been thanked: 429 times
AP155 and LS80 DSII
I thought I would report on my LS80 DSII to AP155EDF f/7 mod. It's pretty straightforward. Remove the Lunt objective and its optical tube, remove the internal ERF, and attach that to an AP155EDF f/7 with a 160mm DERF in front. I removed the AP155's focuser so the pressure tuner would be close enough to the objective.
The LS80 DSII is my 9-year-old LS80 that I love with the circular polarizer and brightened blocking filter.
I positioned it through trial and error for the best view. I found that if I positioned it such that the focal point behind the focuser on the AP155 was identical to the focal point where it would be on the original LS80 DSII, then I got the best high-power view. Super sharp, super contrast, dark background.
The sweet spot is a little smaller than the Sun, as predicted for this 33% etalon diameter versus objective lens. If I push the etalon toward the objective by 20 or 30mm, then I get a nice full disk view and a beautiful medium-power view, but a soft high-power view. When I really want a full-disk view, I just pull the LS80 DSII off the AP155 and put its ERF and objective back on.
You can see the setup in the photo.
I previously have used my DSII unit to double stack a Quark or a Solar Spectrum on my 155. I have two DSII units, so I tried using them double stack, but unlike Brian, I never got a beautiful view. It always looked soft, presumably because the second one (further from the objective) was not operating at its nominal focal ratio. I considered adding a corrector lens to fix that, but just putting the LS80 DSII on it worked better.
George
George
- IMG_4640 copy.jpg (231.31 KiB) Viewed 4404 times
- Rusted
- Has thanked: 8168 times
- Been thanked: 1943 times
Re: AP155 and LS80 DSII
Thanks for sharing your mods.
You seem to be varying your etalon[s] position[s] by trial and error.
Whereas Marty suggests 264mm inside focus.
A figure to which I myself adhered with my iStar 150/10.
I am only interested in optimum position for hi-res imaging.
May one presume it would be worth further experimentation in etalon positioning?
- Has thanked: 4379 times
- Been thanked: 3976 times
Backfocus 264 mm only applies to LUNT LS60MT. Other models have different values. The LS 80TH is 275mm. It should be noted that collimated lenses in the LS80 TH-a etalon will shift the focus back by 1.071x. For the LS80, it will thus change from 560 mm to 600 mm. In the design for larger diameters, this shift must be taken into account. So far, I have only measured the primary Etalon LS80 TH-a, I have to measure how the focus of the LS80 DSII moves when the sun comes out.
- ls80 schema.jpg (201.68 KiB) Viewed 4375 times
- Been thanked: 2725 times
Very nice setup George. Thanks for sharing !
Thanks, all, and thanks for the diagram.
I am thinking that maintaining the same distance between the etalons and the focus is equivalent to measuring the 275+40 in the above diagram and duplicating that in the new setup.
I don't know if using a bigger objective makes you want to shift the focus with respect to the etalons. That is, does that focus shift of 40mm in the above diagram grow or shrink when you move from 80mm to 155mm, or does it stay the same if they are both f/7?
But then yes, I do trial and error for the view to confirm what I got. Keeping the focal point the same resulted in the best high-power view, but there is a wide range of equivalent views (i.e., can shift by 5 or 10mm without a noticeable difference). Pushing the etalon further inward presumably vignettes the objective until you get to the point that the sweet spot is about as large as the Sun, and the low power view looks very nice.
George
George
- Bob Yoesle
- Has thanked: 541 times
- Been thanked: 811 times
Hi George,
I have found the same thing - 10+ mm shifts in the position of the collimator/etalon assembly do not produce much of a noticeable effect. That being said, I still leave mine at the theoretical optimum position with the coincident collimator and objective focal points.
I would think in this ideal position of coincident objective/collimator focal points, and therefore truly collimated light passing through the first etalon, that all the subsequent downstream optics will have the same separations and focal distances, and that this is irrespective for the objective focal ratio. A differing focal ratio between the objective and collimator can affect whether or not the image is 1) vignetted, or 2) restricts the effective aperture of the objective.
You might find this thread of interest from when I was designing another solar telescope with the help of Mike Jones and Vladimir Sacek.
Bob
Bob
- Has thanked: 20805 times
- Been thanked: 10478 times
Great setup and interesting thread!
- Rusted
Thank you Bob.Bob Yoesle wrote: ↑Mon Sep 12, 2022 3:59 pm Hi George,
Bob
It is many years since I wrote my own ray tracing software. [In Basic!]
I am using a 60MT PT etalon as per Marty's project.
- Rusted
Thank you George.george9 wrote: ↑Mon Sep 12, 2022 12:44 pm Thanks, all, and thanks for the diagram.
George
I kept the FT focuser by shortening my main tube on my 150/10.
So I can play with etalon:focus distance to my heart's content.
Thanks, Bob. I remember that thread. Good point, I agree f-ratio should affect vignetting or waste but not distances. As long as the stock configuration is correct, I should be good.
Yes, Rusted, I went into it hoping to use my 4" AP focuser for tweaking, and I could have shoved most etalons up there, but the PT got in the way and I was not prepared to reroute the air pressure cylinder. Nor could I bear to shorten an AP155.
George
George
- Been thanked: 4426 times
Hi George...
Your DSII mod looks great...and kinda familiar too
Well done!
Well done!
- OlegLviv
- Has thanked: 918 times
- Been thanked: 945 times
This is all good but where is sun photo?
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
I am hoping to get some photos when I bring the setup to Black Forest (how I spend the day when I am waiting for the dark sky). I am out of the season for getting the Sun out the window. I am 100% visual except for CaK and the corona shots, but I need to get a good photo through this setup.
For the record, in the stock LS80 setup, I measure the focus being 338.5mm behind the rear of the rear collimation lens of my primary LS80 etalon. I think that correlates with the 275+40=315mm in the figure, as the collimation lens is about 24mm in front of the primary etalon's red shoulder (so 314.5mm). Half a mm is well within my measurement error. I set the AP155 so the focus is at the same point.
George
(EDIT: first version had an arithmetic error. I got 314.5, not 318.5.)
George
- Rusted
George,
Did you remove the red Lunt filter on the nose of the etalon?
Or isn't there one on the LS80 etalon?
I replaced the red filter with the 2" 35nM H-a and the KG3.
I can well understand your desire NOT to cut into that exquisite instrument!
Yes the LS80 has a red filter in front of the primary etalon that unscrews. I am using a Baader 160mm DERF in front of the AP155, so that covers me without additional filters.
Interesting question though. Is that red filter just an RG6**, or also a KG3. I don’t know. But the B1200 should cover long IR anyway.
George
George
- Rusted
Thank you George.george9 wrote: ↑Wed Sep 14, 2022 2:24 pm Yes the LS80 has a red filter in front of the primary etalon that unscrews. I am using a Baader 160mm DERF in front of the AP155, so that covers me without additional filters.
George
I too have a 160mm Baader D-ERF and was shocked at how much heat passes through it.
Easily enough to cause a painful, skin burn near focus. Or produce instant smoke from black foam insulation.
I use the Baader 35nM H-a and Beloptic KG3 to enure that heat doesn't reach the ASI174 camera.
Though I may be an extreme case in regularly tracking the sun for many hours at a time.
I have no idea what the Lunt red filter is. No doubt one of our experts can provide the necessary data.
Chris
Thanks, Chris. This is an important point and worth discussing.
Through the f/7 AP155 and DERF, I can keep my hand at the focus for a few seconds, but not more. And the AP155 puts through four times the heat as the LS80 objective.
My first surface after the objective is the LS80's primary etalon. I have a lot of experience using the DSII etalon as the first surface (when I double stack), and so far at least, no damage or obvious effect.
The DERF is blocked well from 300 to 1400nm other than the 85nm around H-alpha, where it is 95%. I am thinking that not much heat is getting through from 1400nm-2500nm. Important for eye safety, yes, but for protecting the etalon, not sure. (Bob Y's graphs show the heat trailing off as you get that long.)
KG3 protects long IR well but drops 30% of the H-alpha brightness. That's really noticeable in the eyepiece, so I don't use that unless it is the only long-UR protection in the train. The B1800 should cover that for eye safety.
The 35nm H-alpha filter would drop half the heat compared to the DERF (35 vs 85). But it comes in sizes up to 50.8mm unmounted, so say 47mm mounted, and that drops too much from my 52mm etalon.
If the etalons are resilient, then the next risk is the blocking filter. I suspect there's not too much heat by the time you get through 2 etalons and a circular polarizer. Plus the B1800's first element is either blue glass or KG3, either of which are as cheap as the 35nm filter.
So for now, I am just using the DERF, but I will report back if I see any hint of problems with heat management.
George
George
- Rusted
Thank you for your very thorough response George.
I cooked my first ZWO camera. That was their more affordable 120MC.
Back then I was using a 90mm Baader D-ERF internally. Thinking I was safe.
I wasn't. Not remotely! Any claims of a cool optical train is false advertising.
I can share the instant smoke on YouTube if Baader argues with my own findings.
Cooking my ASI174 would probably end my H-alpha imaging. Hence the default 35nM and KG3.
I stopped doing any visual observation after discovering the severe heat problem.
There should be a clear health warning on every Baader D-ERF. IMHO.
I basically use two ERF filters for the 150mm diameter. The first 160mm D-ERF on the lens and the second 55mm ERF from Lunt in front of the etalon. I have UV/IR cut on the camera, so thermal contraception is perfect.
Behind the etalon, the beam temperature is minimal. D-ERF alone will not prevent the burning of the plastic cap in the focus, so temperatures above 150 degrees Celsius.
Wow. Thanks, Chris and pupak.
Chris, was that using the DERF as a photosphere filter (white-light but in red) or with some kind of H-alpha filter?
I certainly would rather not cook my etalon, but my only real concern is vision. The vision seems fine with everything else in the path after the DERF. I have run a spectrogaph on my LS80 although it only went to about 1000nm, not 2500nm. It was well-blocked in the available range.
I guess "cool" was just relative to the older RG630 ERFs (or new hotter DayStar yellow ones), which pass more heat in IR.
Since these ERFs pass 95% of the light in their open band, stacking them shouldn't help that much if they overlap. In other words, two Baader DERFs in series let about the same amount of heat through. A Baader DEF plus a 35nm H-alpha filter does remove extra heat (85nm wide versus 35nm wide).
The DERF plus the Lunt ERF should cut some heat, but not that much. I see the Lunt is RG630. The DERF seems to cut around 615nm, so the RG630, which cuts at 630, may get rid of additional heat in the 615-630 range, which is about 17% of the heat in the 615-700 range that the DERF passes. The UV-IR cut filter should not add much to the DERF, which already has those wavelengths covered. Most UV-IR cut filters don't go below 1100nm or so (I think). The etalon and blocking filter are doing the most work in reducing heat after the DERF in that setup.
So compared to someone who has multiple ERFs, I am letting through either twice the heat (35nm H-alpha) or roughly the same amount (second ERF, CCD red filter, etc.).
I do see a benefit from redundancy in keeping everything safe. Having an internal ERF means if you forget the front ERF, you don't instantly cook everything behind it. Lunt makes sure that if you forget the blocking filter or if you forget the telescope and have just the blocking filter, you will get something very bright but won't go blind. For fully home-built filters, I usually put a BelOptik KG3-UV-IR (plus usually an ND1 or even ND3 at first look) in series just in case I made a mistake setting up.
George
George
I admit I haven't measured anything, but two ERFs in tandem will give a heat in the focus that I can barely feel on my hand, where only the D-ERF burns me instantly. This is authoritative for me.
Thanks. This is worth looking into more. I like both testing it out and understanding it theoretically. Then I feel safe.
Just to confirm, pupak, you are comparing DERF in front of a 150mm refractor versus DERF in front and Lunt ERF in the middle and no other filters anywhere.
I can test that out. I have the ERF that comes with the LS80, but not sure it is identical to yours. I also have a separate RG630.
Could be that the DERF lets through more light than it is spec'd for.
Could be the Lunt ERF is not just an RG630 but also has some other filtering. Or that it is not near 100% transmission around H-alpha for some reason.
Note that the Lunt ERF that I have is absorptive, not reflective, so if the DERF is sending through a ton of heat and the Lunt is internal and absorbing it, be good to check its temperature in operation. It may not be a problem because the heat is spread over a wide area, not just a focus point.
George
George
I tried it out and here is what I get. I used a Pronto, which is 70mm and f/6.8, so the heat per area of skin should be the same as my AP155 f/7.
No filter - very hot, need to move right off
DERF - warm, I can leave it there for seconds, but I can tell it is heating up
DERF + Lunt ERF - noticeably less warm, heats up maybe half as fast
Then I looked through my hand spectroscope. The Lunt ERF cuts at 630, as predicted. The DERF cuts not at 615nm but at about 600nm. I found a spectrum for it online that matched the 600 (previously I found the 615 one). That means the RG630 will be helping even more, cutting 600-630.
So it seems for mine, it cuts the heat about in half. If I remember Bob's graph, in terms of solar radiation dropping off, 600-630 may be similar to 630-700 in amount of heat. So it could all fit.
George
George
- Rusted
Is there a suitable target which could measure the temperature at certain points in the focused beam of our telescopes?
I'm thinking of using the handheld "pistol" {remote or laser guided thermometers.] Now inexpensive thanks to widespread use on human foreheads.
These tools can't measure the air temperature directly. So would need a suitable, non combustible target to read local heat intensity.
That target would probably have a black finish, be metallic and needs to have a low thermal capacity. Allowing it to heat up and cool rapidly.
Chris, your wish is my command.
I have an IR thermometer but the Pronto (70mm f/7) solar image is so small that it mostly counted the area around it. I switched to a quick-read meat thermometer and used heat grease to thermally connect it to a small black metal clip that was clipped to a wood bar. (Forgot to take a photo.) I timed the temperature rise in 30 seconds at focus. Here are the results.
Pronto by itself: 85 deg to 325 deg = 240
DERF to Pronto: 89 deg to 135 deg = 46
DERF to Pronto to Lunt ERF: 85 deg to 110 deg = 25
So more or less a ratio of 10:2:1. The DERF passes 20% of the heat (which sounds familiar) and the Lunt drops half the heat from the DERF (which matches my last post).
George
George
- Rusted
Thank you George!
You have obviously gone into the thermal issues with some rigour.
I thought it only myself who obsessed over such details.
I keep an eye on SharpCap's monitoring of camera temperature.
The high 40sC seem quite normal after some hours of solar tracking with a {supposedly] D-ERF protected 150mm.
Though even these readings may have nothing [whatsoever] to do with heat infall on the sensor.
Which is my own greatest worry.
If you use cameras from ZWO, then 42-45 degrees is normal. It is evident that the ZWO camera does not have a thermal bridge between the chip and the body. The active cooler will reduce the temperature of the chip from 42.6 to 35.1 degrees. Celsius at an ambient temperature of 26 degrees. Celsius. This is important for chip protection. It should not exceed 50 degrees. With high-quality filtration, the influence of heat and sun is negligible. The electronics of the camera heats up more.Rusted wrote: ↑Sat Sep 17, 2022 5:50 am Thank you George!
Thanks. I defer to you two on cameras. I do have a ZWO ASI1600 pro, but since I am using it mostly on my coronagraph, there is not too much heat getting to the camera, and I have not really used its cooler very much. I ought to, though, because the corona is so dim that I need long exposures, up to 2 seconds.
This is a little off the original topic but relevant to this part: Temperature is important to me because my corona filter on my coronagraph (i.e., my other scope) is very temperature sensitive. I made my own oven, but my attempts at a Peltier cooler didn't go so well (the challenge is mainly insufficient back focus to fit much instrumentation and a desire to keep it lightweight due to the very long optical train). So we picked a filter temperature, 32C, that we thought would be below ambient most of the time. We are usually on a mountain, and that helps. I have experimented with ice packs, but haven't had to use them yet. If you pick too high a temperature, then it takes forever to heat up to that level in the cooler months and you get bigger gradients across the filter or filters.
But in designing the coronagraph, I was measuring the temperature in the back end of my 155mm H-alpha filter, and in the summer (up to 34C outside) I saw temperatures up to 46C around the inside of the diagonal! That's without direct sunlight, neither inside nor outside. It was after most of my H-alpha filter, so there could not have been much solar energy left. My Solar Spectrum ran at 50C, and so heat probably transferred back when I used that filter, but I don't think that was the only hot setup. It may also have been external sunlight hitting the binoviewer, transmitting heat back to the shaded diagonal. A better shade would help. But my point is that I was surprised, and measuring was useful.
(Also, by the way, my temperature measurements corroborate pupak's experience with the ERFs. 135C feels too hot to touch, and 110C feels comfortably warm. I am sure the temps are different between the two, but the point is that amount of heat difference can swing it quite a bit.)
George
George
Ah ha. For the record, it just dawned on me why pushing my etalon in 20mm too far would solve the low-power sweet-spot problem. I had thought perhaps vignetting the objective, but at f/7, that's only 3mm, and I would need to vignette 50mm.
I suspect when I push it in 20mm, the beam out of the front colllimating lens is no longer collimated, which would broaden the bandwidth of the etalon with some shifted blue-ward by the tilting of the rays. So parts of the image that should be out of band now have some H-alpha signal in them. It is hard to predict exactly what it would look like by theory alone, but in practice, by shifting the tuning of the etalons and by refocusing the scope, I get something that looks pretty good at low power. I don't remember seeing a double limb even in this configuration. And sharp enough for low power.
At high power, it was definitely soft, probably mostly due to the optical aberrations of using the collimating lenses out of their proper place.
George
George
Shifting the etalon does not change the angle of the beam, but only the area hit by the cone of light from the lens. The primary focus F1 should be the same as the focus F2 of the negative coimating lens. This is the optimal position of the etalon in the lineup.
- kolim.jpg (860.78 KiB) Viewed 2049 times
Sorry, I should have been more clear. My negative collimating lens is attached to my etalon. When I say I moved the etalon 20mm closer, I really meant I moved the negative collimating lens 20mm closer. That changes the effective focal ratio seen by that lens. It looks like a longer focal ratio because F1 is now further back behind the collimating lens (put another way, the collimating lens is only seeing the middle of the objective's beam, which means a higher f-ratio). But F2 didn't change with respect to the collimating lens, so there is a mismatch, and the beam coming out is no longer collimated. I think it is a little divergent. (But please double check.)
George
George
You are only interested in the angle of the beam with respect to the Etalon, and it does not change with displacement. The area of the etalon should be used efficiently.
I just drew a diagram to check my work. If you push the negative collimation lens toward the objective, then you no longer have a collimated system.
The top ray trace is collimated. The distance, x, is the same from the collimation lens to F1 and to F2. Their focal ratios are about the same, around f/4.
If you move the collimation lens by distance x toward the objective, then the collimation lens sees f/8, as the distance from the lens to F1 is now 2x, or about f/8. But the lens stayed the same, about f/4. If the objective was a 100mm f/4, then the negative collimation lens sees only the middle 50mm, which again looks like an f/8.
As a result, the rays coming in diverge at the other side. (Sorry about the crossed-out lines; they looked too much like the result of a parallel beam coming in.)
As you say, it is important that the distance from the lens to F1 and to F2 be the same. When you push it in, the two distances are no longer the same.
George
George
- Collimated.jpg (121.76 KiB) Viewed 2038 times
