Ha belated images / May 5 / C8 EdgeHD / double stack Ha
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Here are some old Ha images taken on May, 5 with the C8 EdgeHD:
http://astrosurf.com/viladrich/astro/so ... -SMn35.jpg
A group of sunspots hardly visible with the double stack filter, since it is nearly completely covered by fibrils :
A set of prominences, some shows very fine details while others look fuzzier:
http://astrosurf.com/viladrich/astro/so ... -PE06A.jpg
Clear skies
Christian
OlegLviv
Has thanked: 910 times
Been thanked: 938 times
Re: Ha belated images / May 5 / C8 EdgeHD / double stack Ha
Post by OlegLviv »
Very very good!
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
christian viladrich
Has thanked: 1 time
Oops, wrong place ...
Thanks Oleg !
pupak
Has thanked: 4376 times
Been thanked: 3971 times
Post by pupak »
Excellent photos. It can be seen that the diameter of 200mm will do its job. With my AR150/F6, I was only able to capture details when there was really exceptional seeing.
OlegLviv
Post by OlegLviv »
I bought HD8 special for sun but dont buy ERF=))))
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Has thanked: 20738 times
Been thanked: 10432 times
Super images as always Christian!
Has thanked: 17807 times
Been thanked: 16943 times
Post by DeepSolar64 »
Superb work Christian. I would consider getting a C8EdgeHD vs a 152mm refractor.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Superb images Christian.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 8523 times
Been thanked: 8252 times
Post by Carbon60 »
Superb again, Christian.
christian viladrich
Has thanked: 1 time
Thanks to all !
Has thanked: 17895 times
Been thanked: 8888 times
Absolutely exceptional :bow :hamster: I see that some areas of the prom are very detailed whereas other areas are soft. I have seen this before in my own images, I wonder if these areas are moving faster (motion blur) compared to other areas or whether it is just different structures within the prominences.
arnedanielsen
Has thanked: 6276 times
Been thanked: 7289 times
Post by arnedanielsen »
Awesome images, Christian!
Every time I see images from your hand I dream of larger aperture :-) I do know however that it's more to more to it - like good seeing and acquisition and processing skills!
Arne
Arne
BGazing
Has thanked: 289 times
Been thanked: 351 times
Post by BGazing »
Unbelievable.
Lunt 80MT DS, 533/1600/462
christian viladrich
Has thanked: 1 time
Thanks guys !
Montana wrote: Thu Sep 15, 2022 2:07 pm Absolutely exceptional :bow :hamster: I see that some areas of the prom are very detailed whereas other areas are soft. I have seen this before in my own images, I wonder if these areas are moving faster (motion blur) compared to other areas or whether it is just different structures within the prominences.
Indeed Alexandra, this is something a bit puzzling. I investigated it by reducing the length of the film used for stacking by Autostakkert 3 to about 10 s. You can do it by choosing the option "limit" at the right of the "open" button"
There was no difference at all in the result, meaning no motion blur. So, for some reasons, some prominences look a bit soft. Maybe we have overlapping structure along the line of sight ? I don't know.
This is a bit the same for the spicules visible at the solar limb. A few of them are moving very fast, but others remain very soft even if the duration of the film is reduced to 5 - 10 s, and others are very sharp.
