OIII images taken with the 300 mm on August 5
- Been thanked: 2725 times
Here are some other belated images taken on August 5 at St Véran.
I kind of like this first one. We can see that the right border of the umbra of these two spots is brighter than the left border. If we remember that the umbra is at altitude a bit lower than the filaments (and the granulation), we can figure out that this effect is explained by a perspective effet.
These spots being close to the solar limb, the bright "head" of the filaments (= the part close to the umbra) is directly visible on the right border of the umbrae. On the opposite, it is hidden on the left border because of its lower altitude:
http://astrosurf.com/viladrich/astro/so ... 0-OIII.jpg
The diversity of size and shape of the granules :
Clear skies
Christian
Clear skies
Christian
- JochenM
- Been thanked: 1619 times
Re: OIII images taken with the 300 mm on August 5
I kind of like it as well
Out of curiousity, what's the reasoning behind using the OIII filter? The shorter wavelengths will be a lot more sensitive to conditions being right (not like that's an issue by the looks of it, but still), so I'm guessing there must be a specific purpose?
- banjo
- Has thanked: 2123 times
- Been thanked: 2903 times
- Has thanked: 1640 times
- Been thanked: 878 times
Excellent HR shots. I always appreciate excellent WL images.
- Has thanked: 2501 times
- Been thanked: 4928 times
Great HR WL images Christian, nice to see the detailed convection cells.
- Petrus
- Has thanked: 1615 times
- Been thanked: 776 times
Wonderful images Christian, as always. So many details to look for. Thank you for sharing!
~ Petrus ~
Flickr
Flickr
- Has thanked: 9387 times
- Been thanked: 6201 times
Thanks guys !!
Jochen, there are different factors involved in the choice of the filter :
- seeing quality decreases when going to the blue (i.e. it is more difficult to have good image in the blue),
- diffraction decreases in the blue (i.e. resolving power of a reflecting telescope increases),
- contrast of solar features visible on the photosphere increases in the blue.
On top of that, an often overlook factor is atmospheric dispersion. The atmosphere acts like a prism, star images are vertically dispersed a bit like a small spectrum.
Dispersion increases to the blue, and with the width of the filter bandpass.
For example, when the Sun is 30° above the horizon, atmospheric dispersion with the OIII filter (12 nm bandpass) is 0.09 arsec, much lower that the resolving power of the 300 mm Newtonian.
With a typical green filter (100 nm bandpass), atmospheric dispersion would have been 0.6 arsec, which is larger than the resolving power of the 300 mm telescope.
So finally :
- the choice of the color of the filter (blue, green or red) depends on the seeing (and on the telescope aperture),
- the choice of the bandpass depends on the height of the Sun above the horizon. Using 12 nm filter (or lower) solves this last issue neatly.
So finally :
- Has thanked: 6353 times
- Been thanked: 7411 times
Amazing results as always Christian!
Arne
Arne
- Sumpy
- Has thanked: 324 times
- Been thanked: 388 times
Holy smokes these are incredibly detailed!
- Has thanked: 20962 times
- Been thanked: 10593 times
Super images there Christian!
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Fantastic images Christian.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 1918 times
- Been thanked: 1352 times
Holy Smokes they look great
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
- Has thanked: 8596 times
- Been thanked: 8325 times
Yet again, mind blowing images, Christian. Superb
Thanks a lot !
- Has thanked: 18105 times
- Been thanked: 8942 times
I'm glad you brought up the perspective of the spots, I hadn't thought of that and now I will look for it
- Has thanked: 17960 times
- Been thanked: 17110 times
VERY nice high resolution work Christian. I always enjoy your work. Thanks for sharing.
JP
JP
