Sun FD in H-Alpha and CaK 14th of September 2022
- Has thanked: 6305 times
- Been thanked: 7324 times
Dear friends,
A short spell of blue allowed for a quick imaging session in the afternoon. I managed to get H-Alpha and CaK, but it clouded over before I was able to do Continuum. A very impressive prominence to be seen in H-Alpha and lots of active areas in CaK.
Click on images to view them in full size on AstroBin.
FD image in H-Alpha using a Coronado 60mm/BF15 w/Beloptik ITF, stopped down to 50mm, Baader 35nm H-Alpha and ASI 178mm mounted on a SkyWatcher SolarQuest.
FD image in CaK using a FLO StellaMira 80mm ED f/10, stopped down to 60mm, Lunt CaK 1200 module and ASI 183mm camera mounted on a SkyWatcher SolarQuest.
Arne
Arne
- Sumpy
- Has thanked: 324 times
- Been thanked: 388 times
Re: Sun FD in H-Alpha and CaK 14th of September 2022
Super impressive as always, Arne! You really did that massive hook shaped prom justice - it looks great in your image!
- Been thanked: 10489 times
Lovely disks Arne, thanks for sharing!
- Has thanked: 8559 times
- Been thanked: 8290 times
Impressive images, Arne. You’ve gone from strength to strength
- Has thanked: 4379 times
- Been thanked: 3976 times
Excelent pictures.
- Has thanked: 9319 times
- Been thanked: 6157 times
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
Excellent disks Arne! Those CaK images are massive!
Such a pleasure to enjoy on Astrobin. I was marveling at your first posted image. Do you do two separate prom and surface shot or modify the surface shot? Whichever way you do it I cannot notice the processing, it is very masterful and naturally done
Thank you so much everyone for all your kind comments!
Alexandra: I do a separate recording for the pure prom image with a longer exposure time to increase the s/n of the prominences. For the disc/prom the typical exposuretime with this setup is 3.5-4ms using neutral gamma. For the prom shots I use 12ms and a gain setting of 65 in FC.
Here you can see the stacked and sharpened versions before doing any contrast stretching. Best regards,
Arne
Arne
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Fantastic images Arne.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Been thanked: 4427 times
Fabulous images Arne...well done
Your Ha etalon is one of the best Arne
Thank you very much Alun, Brian and Mark!
Mark: I'm very happy with the performance of this setup.
Arne
Arne
