Sun - Ha & White Light Full Disk - September 14, 2022
Sumpy
Has thanked: 324 times
Been thanked: 388 times
Post by Sumpy »
Earlier this week James noticed artifacts in my WL images that I hadn't really noticed before, and those artifacts turned out to be noise that had crept in during the ImPPG step. I've cut way back on the LR sharpening in ImPPG for the WL images today, and also cut LR sharpening back a bit on the Ha image as well.
I know that sharpening for solar work is a fine balance between the soft, fuzzy, non-distinct surface of the sun, and actually being able to see contrast and detail in the image. Any thoughts on if I am still over sharpening? I welcome any input or suggestions.
And dang take a look at that massive prominence! :)
WITHOUT #58A GREEN FILTER:
WITH #58A GREEN FILTER:
Has thanked: 20756 times
Been thanked: 10442 times
Re: Sun - Ha & White Light Full Disk - September 14, 2022
You get lots of clear skies in Greenville! Great disks Brian!
mattwastell
Has thanked: 2 times
Been thanked: 72 times
Post by mattwastell »
Hello Sumpy.
Great presentation - I really like the Ha & prom disc images.
Happy days.
Matt Wastell
Look up, look good!
http://www.pbase.com/mattwastell
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Beautiful presentation Brian.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 8523 times
Been thanked: 8258 times
Post by Carbon60 »
Excellent, Brian. Great images and presentation.
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Hello Brian,
The Ha image is nicely processed !
Regarding the WL image, the image with the W58A is slightly better. Still, if you can, I would suggest to use a trichromic green filter (Astronomik, Baader CCD, ZWO, etc.). Indeed, the W58A transmits IR light, which is recorded by the camera, reducing the contrast and resolution of the image. You would have a better resolution with a trichromic green filter.
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
A great set Brian
rigel123
Has thanked: 8547 times
Been thanked: 8781 times
Post by rigel123 »
Nice ones Brian!
Sumpy
Post by Sumpy »
Thanks so much for the kind words, all! Still trying to improve day by day. :)
christian viladrich wrote: Thu Sep 15, 2022 9:24 am The Ha image is nicely processed !
Thanks Christian - I greatly appreciate your insight!
When you say trichromatic, do you mean like the Baader CMOS optimized green filter, or the Baader 500nm bandpass green filter? I assume the latter?
500nm Bandpass Green: https://agenaastro.com/baader-green-fil ... 58304.html
I've been searching for a solar continuum filter that is in stock with no luck, which led me to try the green filter I had on hand.
Has thanked: 17925 times
Been thanked: 8894 times
These are absolutely cracking images :bow :hamster:
christian viladrich
Has thanked: 1 time
Sumpy wrote: Thu Sep 15, 2022 1:39 pm Thanks so much for the kind words, all! Still trying to improve day by day. :)
I meant filters with a "square" transmission curve. These filters have a high peak transmission and cut most of the IR. For example :
Baader CMOS optimized :
https://www.baader-planetarium.com/en/b ... mized.html
ZWO :
https://astronomy-imaging-camera.com/pr ... ed-asi1600
Astronomik :
https://www.astronomik.com/en/fotografi ... rsatz.html
You just need the green filter, not the whole LRGB set.
The Baader continuum is a bit dark (because of its narrow bandpass), this is why I would rather recommend a green filter.
Sumpy
Post by Sumpy »
Got it - thank you again, Christian!
arnedanielsen
Has thanked: 6276 times
Been thanked: 7296 times
Post by arnedanielsen »
Great set of images, Brian! Love the different presentations!
Arne
Arne
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Somehow I missed this one. Great job Brian. I especially love the blackout image!!
Sumpy
Post by Sumpy »
Welcome. :-)
