Large prom in Ha & CaK 220914
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Using the 90mm f/10 achromat with PST mod module (100mm Lunt ERF up front) and then the Lunt Cak B1200 diagonal and QHY5III 178M to image the large prominence on the south east limb today (images orientated for viewing). With the PST mod I had to capture two panes for the prom and the same again for the limb detail due to keeping within the sweet spot as I wanted to capture the same area as covered in the CaK image. All stacked in Autostakkert,Photoshop CS2 for stitching the Ha panes together then using layers to combine the proms and limb images,then into Astrosurface for wavelet treatment.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- rigel123
- Has thanked: 8316 times
- Been thanked: 8544 times
Re: Large prom in Ha & CaK 220914
Excellent Alun!
- Been thanked: 4787 times
- Has thanked: 8418 times
- Been thanked: 8165 times
Nice, Alun. Lovely prom.
- Alun_H
Thank you for the kind comments guys.
In regards my colouring the limb and leaving the proms in greyscale,I use the selection tool in Photoshop and draw round the edges and use modify to
expand or contract the "marching ants" to fit then colourize.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 9145 times
- Been thanked: 6026 times
- Alun_H
Thank you Franco.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Been thanked: 8793 times
Super!! it is lovely to see the CaK proms to compare with the halpha
- Arrakis97
- Has thanked: 350 times
- Been thanked: 306 times
Beautiful detail, especially in the Ca-K wavelength. Thank you for sharing.Alun_H wrote: ↑Wed Sep 14, 2022 9:50 pm Using the 90mm f/10 achromat with PST mod module (100mm Lunt ERF up front) and then the Lunt Cak B1200 diagonal and QHY5III 178M to image the large prominence on the south east limb today (images orientated for viewing). With the PST mod I had to capture two panes for the prom and the same again for the limb detail due to keeping within the sweet spot as I wanted to capture the same area as covered in the CaK image. All stacked in Autostakkert,Photoshop CS2 for stitching the Ha panes together then using layers to combine the proms and limb images,then into Astrosurface for wavelet treatment.
- Alun_H
Thank you Alexandra,Arrakis97.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Been thanked: 4340 times
Nice catch in both wavelengths Alun
- Been thanked: 10248 times
Nice results there Alun!
- Has thanked: 6181 times
- Been thanked: 7142 times
- Alun_H
Thank you Brian,Mark and Arne for the kind comments.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
