Belated Ca K images / July 10 / Taka TOA 150
- Been thanked: 2713 times
Now here are some Ca K images taken on July 10 with a double-stack configuration (Alluxa 0.37 nm + Barr 0.26 nm) and the TOA150.
The full-disk image :
http://astrosurf.com/viladrich/astro/so ... SI1600.jpg
The same image with different vizualisation to show prominences :
http://astrosurf.com/viladrich/astro/so ... 00-ddp.jpg
For comparison, an image of the photosphere. We can see that the location of the facular regions visible with the 396-5nm filter matches the location of Ca K bright plages:
One of the two groups showing a small flare :
http://astrosurf.com/viladrich/astro/so ... a-Barr.jpg
The other group :
Clear skies
Christian
The other group :
Clear skies
Christian
- Has thanked: 9144 times
- Been thanked: 6025 times
Re: Belated Ca K images / July 10 / Taka TOA 150
These are great Christian. So much fine detail in there.
- Been thanked: 4786 times
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Terrific set of images today, Christian.
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
- Has thanked: 20424 times
- Been thanked: 10243 times
Stunning images as always Christian.
How much distance have you between the Barr and the Alluxa filters in the optical train?
- Has thanked: 8415 times
- Been thanked: 8161 times
Superb images, Christian.
- Has thanked: 17667 times
- Been thanked: 8788 times
Wow!! I do really love the prominence full disc and the CaK close ups are to die for
Thanks to all !
Stu, the distance between the Barr and the Alluxa filters is about 10 mm. You can have a look at the setup here :
http://astrosurf.com/viladrich/astro/in ... onomik.jpg
However, when I double-stack the Alluxa 0.37 nm with the Alluxa 0.15 nm, I definitely need more spacing (40 mm or more), otherwise I have huge glaring. I still have to optimize this second setup. It is a bit tricky.
I thought they were close based on prom full disk image.christian viladrich wrote: ↑Fri Sep 16, 2022 4:49 pm
I also found the same thing as you, and have my 2 CaK filters with as much distance as possible, this pretty much gets rid of all glaring and lowers the black point (close to 0).
Could you mount one of the filters on the nose of the FFC to get a bit more distance?
Hello Markmarktownley wrote: ↑Sat Sep 17, 2022 6:52 amI thought they were close based on prom full disk image.christian viladrich wrote: ↑Fri Sep 16, 2022 4:49 pm
I wouldn't try it for two reasons :
- the filter would be exposed to the f/7 focus. That would be a lot of energy over a small surface. I already cracked a Baader K-line this way ...
- because of the f/7 focus, the FWHM would broaden.
I am more or less thinking of trying the AiryLab telecentric instead of the FFC in order to have more flexibility in the distance between the Ca K filters.
Or maybe go back to the Basler 1920-155. Its larger pixels would mean a larger distance to the FFC. Still, I remember I had a lot of glaring when I used the Basler and the Ca K filters.
I need to make some systematic testing there ...
Hiya Christian
Ahhh yes, f7 is going to fry things very quickly, not thought of that!
I've been very impressed with the Airylab telecentric for CaK, but I always run it on an f10 system, not sure what would be like on f7. It would certainly give you more distance to play with for filter spacing.
- Has thanked: 6181 times
- Been thanked: 7142 times
Another fantastic collection, Christian!
I'm particularly impressed with the high-res and the CaK prominences.
Arne
Arne
Very nice photosphere image!
Stellarvue 152 mm
APM Hershel Wedge
Coronado II 90 mm BF 30 DS
iOptron 120 mount
APM Hershel Wedge
iOptron 120 mount
- Been thanked: 16693 times
Christian,
These blew me away!!
