A very uncooperative sky today with a constant threat for clouds creeping into your frame. Recordings had to be limited to 600 frames or less to avoid cloud shadows messing up the files. While recording, I had to feep glancing up to check that clouds weren't drifting over the sun. At one point grey clouds bunched up so thick that it looked like imminent rain.
I packed up. Then, a quarter hour later, it mostly cleared and I went back out.
Images were obtained in the somewhat turbulent clear regions between clouds and turned out ok.
The full disk was done using a 2 panel mosaic using a double stacked LS60MT + a 2.3x Baader barlow on an ASI1600.
The higher res images were done using a 135 Baader D-ERF on a Stellarvue 127 with a Quark Chromosphere on an ASI1600.
For one image I double stacked the Quark Chromosphere with a PST etalon on the Quark.
Lou
The next 3 used a Quark Chromosphere double stacked with a wobbly PST etalon on a Stellarview 127
Hide and seek on Sept15
- Been thanked: 1735 times
- Has thanked: 17667 times
- Been thanked: 8787 times
Re: Hide and seek on Sept15
I like the pink Sun a great set and I am glad you had the patience
- Been thanked: 4786 times
- Been thanked: 16691 times
Beautiful work Lou! I love the first full disc image.
- rigel123
- Has thanked: 8310 times
- Been thanked: 8537 times
Great images Lou, but I'll be real honest and say the pink is not my favorite! But then again, I'm pretty much B&W only so probably in the minority!
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Great set of images Lou.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
Hi, Warren
I'll probably look for another colour scheme eventually to replace the pink tone just as I got a little tired of the more natural colour. Black and white is actually my preference too maybe because it reminds me of the first Ha images I saw long ago and perhaps because it involves less processsing.
Lou
Lou
- Been thanked: 4340 times
Superb set of images Lou...well done
- Has thanked: 20424 times
- Been thanked: 10243 times
Lovely shots there Lou!
- Has thanked: 6181 times
- Been thanked: 7142 times
