September 15 2022 Imaging Session.
- Been thanked: 16694 times
Today I imaged between 14:30 and 15:00 UTC. The skies are mostly clear and the temperature is 67F ( 19.4C ). The seeing is well below average to poor. I used the SMII90 in both SS and DS for Ha with the Point Grey Grasshopper camera with ASTRO IIDC running on the MacBook Pro. Additional editing/processing was done in GIMP and Paint.net. The 540nm images were done using the Celestron 102 with the Baader filter screwed into the nosepiece of the camera.
Here's what I got. Definitely not my best.
- Been thanked: 8791 times
Re: September 15 2022 Imaging Session.
Great images James, the WL is spot on on the 3rd image down, what you have on the very bottom right hand side of the image is what you need to get in the middle so that the whole solar disc is on band. Can you move the etalon tuning so that the on-band area is more towards the camera chip area?
Alexandra,
I fiddled like crazy trying to get the disc all on band. I never quite succeeded. It's more important when imaging to do this Vs visual since you can move the scope around and see all that is there through the on band section. With imaging it has to be right and tuning has to be full disc to look right. With single stacking I have it much easier. I always struggle with doublestack tuning while imaging. I bet those Lunt pressure tuned scopes are easier!!
- Has thanked: 1640 times
- Been thanked: 878 times
Thanks!
- Been thanked: 10247 times
You're getting good at this imaging James!
Thanks Mark. I try...
- Has thanked: 6181 times
- Been thanked: 7142 times
Thanks Arne!
- Has thanked: 2924 times
- Been thanked: 424 times
Nicely done James
Lunt pressure tuned 60mm
Orion ST 80mm
Bausch and Lomb 90mm
Starfield 2" herschel wedge
various Barlows and Filters
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
Apollo Mini IMX 429m
Apollo -M Max IMX 432m
Sky Watcher SolarQuest
EQ 5 Black
Orion ST 80mm
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
EQ 5 Black
Thanks Bill!
- Has thanked: 9145 times
- Been thanked: 6025 times
James: it is great to see you imaging more often with your new gear. Very good results and getting better all the time !
I just finished processing today's images. I'll post some of them shortly. Thanks Franco.
