http://brierleyhillsolar.blogspot.co.uk/ Solar images, a collection of all the most up to date live solar data on the web, imaging & processing tutorials - please take a look!
BGazing wrote: ↑Sun Sep 18, 2022 6:40 pm
Great stuff! How do you do that exagerrated effect of prominences vs disk in processing, if you do not mind me asking?
Thanks BGazing! The proms and disk are shot with different exposures, and combined during Photoshop processing. If you mean the slight glow around the proms, it is mainly just curve tweaks trying to pull out all the detail on that layer. I also often do an overlay layer so I can dodge and burn areas selectively as needed. Sometimes I've noticed when seeing isn't that great there's almost a slight 'haze' that gets exaggerated when I pull the curve up.
