SOLAR300 Continuum - AR13089 sunspot with a strange flash
Laszlo Francsics
Been thanked: 258 times
Post by Laszlo Francsics »
AR13089 sunspot with a small and sudden flash. Can it be a small fler in Ca-K?
Monochrome and color processing.
  • 300/1200 uncoated Newtonian
  • ASI 174 MM
  • 0,5 ms - 4000/400 frames
  • Edmund Optics 394/10 nm 25 mm/ZWO Blue (ERF)
  • poor seeing - zero wind - through 40% density cirrus clouds
The small flash (took about 30 minutes) was visible on the live video and on the raw stack as well.
Laszlo Francsics
inventor, founder, deep thinker of Soleye
https://www.soleye.eu/
chairman of the Hungarian Astrophotographers' Association
https://magyarasztrofotosok.hu/en/
juror of the Astronomy Photographer of the Year competition
Has thanked: 9319 times
Been thanked: 6157 times
Re: SOLAR300 Continuum - AR13089 sunspot with a strange flash
Post by ffellah »
Great images Lazlo !
Has thanked: 20819 times
Been thanked: 10489 times
Top shot! One of our other members of the forum has reported a very similar thing in another active region recently, in white light, maybe these things are more common than we might think...
Laszlo Francsics
Hi, thank you for your kind comments!
This flash must be a common phenomenon, however, it was unusall for me.
Laszlo
Laszlo Francsics
Has thanked: 17974 times
Been thanked: 8906 times
That's absolutely terrific :bow :bow :bow I have caught one of these before and asked the Kanzelhohe team, they reckoned it was a bright penumbral grain viewtopic.php?t=35468
Like a mini flare.
It is very exciting to see and quite rare but much more common than a true WL flare.
:bow :bow :bow
BGazing
Has thanked: 289 times
Been thanked: 353 times
Post by BGazing »
Congratulations, that is really something special.
Lunt 80MT DS, 533/1600/462
Alun_H
Has thanked: 648 times
Been thanked: 622 times
Post by Alun_H »
Superb images Lazlo :bow :bow
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Then there is all the night kit which is far too long a list to write up here! :lol:
Has thanked: 17853 times
Been thanked: 16996 times
Post by DeepSolar64 »
Laszlo,
This is with a wide band CaK filter, right?
It looks like a small flare to me. The reason I asked about the filter is that flares should be considerably easier to see in CaK than in continuum. A flare has to be unusually intense to be seen in white light.
Great catch!
Is a penumbral grain the same as a flare kernel? I hear flare kernels are visible in narrowband Sodium filters. A flare kernel may be where the flare is rooted to the photosphere? :?
Laszlo Francsics
Montana wrote: Sun Sep 18, 2022 5:26 pm That's absolutely terrific :bow :bow :bow I have caught one of these before and asked the Kanzelhohe team, they reckoned it was a bright penumbral grain viewtopic.php?t=35468
Like a mini flare.
:bow :bow :bow
Hi, thank you very much for your kind comment. The bright penumbral grain is new for me, I have to understand what it is exactly, thank you for the idea.
I agree, that it couldn't be a WL flare. I have checked the flares, and only C8-C9 class flares appeared at that time in the region. They are to weak to appear in WL.
Laszlo
Laszlo Francsics
Laszlo Francsics
DeepSolar64 wrote: Sun Sep 18, 2022 7:04 pm Laszlo,
Great catch!
Hi, thank you!
yes, it is a wide band CaK, 10 nm.
I have a feeling, that it worked simultaneously with another bright area in the other sunspot in the middle, but I can't prove it.
Laszlo Francsics
Has thanked: 64 times
Been thanked: 4427 times
Post by MapleRidge »
Hi Laszlo...
Excellent images and very fortunate to be able to share this flash you caught too :bow
Well done,
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Very interesting. Well done !
Has thanked: 8559 times
Been thanked: 8290 times
Post by Carbon60 »
Great images and lucky capture. Very nicely done Laszlo.
arnedanielsen
Has thanked: 6305 times
Been thanked: 7324 times
Post by arnedanielsen »
Wonderful images Laszlo!
Thanks for sharing your amazing work!
Arne
Arne
Laszlo Francsics
Thank you for all the kind comments, especially for the SPOD!
Laszlo
Laszlo Francsics
Well deserved Laszlo. 👍🏻
MAURITS
Has thanked: 2464 times
Been thanked: 4880 times
Post by MAURITS »
Great details Laszlo.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
