Saturday Sunshine 17th September
- Been thanked: 10247 times
It's been over a month since i've been able to image the sun - too long! And so when saturday was forecast decent weather I was not going to let the opportunity pass. As Stu noted seeing was poop, meteoblue was telling me 1.7" and worsening. I decided to try 60mm in CaK and 90mm in Ha, this was pushing things and I struggled to get much, with the close ups in Cak all being mush. I think seeing was probably closer to 2" (in the good bits!).
Anyway, I did a quick look on GONG and saw a lack of any real proms, so was pleased with what the SM90 (single stack) revealed. This was taken at prime focus withe the zwo183mm camera. Lots of zoom in on Flickr.
Ha FD SM90 zwo183mm-Recovered by Mark Townley, on Flickr
The CaK disk was taken at 60mm f10 (ED80 stopped down to 60mm), again with the zwo183mm and the home brew CaK filter.
CaK FD 60mm f10 zwo183mm bw by Mark Townley, on Flickr
Going to have a look at the closer views and see if there is any salvage...
Hope you like these
Hope you like these
- Has thanked: 9145 times
- Been thanked: 6025 times
Re: Saturday Sunshine 17th September
I really like your disks, Mark. The Ha disk has excellent resolution when you enlarge the image.
- Been thanked: 4340 times
Hi Mark...
Superb FD images...like them indeed
- Has thanked: 230 times
- Been thanked: 176 times
Great FD Mark! The CalK image reveals so many Ellerman bombs.. excellent!
Stephen
Stephen
- Has thanked: 8418 times
- Been thanked: 8163 times
It’s so frustrating to find the time to image on a sunny day only to find the seeing really letting things down for hi-res work. Good job we have FDs to fall back on. Very nicely done in both lights. That home brew CaK setup works really well.
Thanks guys! Here's the colourised versions of the disks:
Ha FD SM90 zwo183mm-colour by Mark Townley, on Flickr
CaK FD 60mm f10 zwo183mm colour by Mark Townley, on Flickr
- rigel123
- Has thanked: 8314 times
- Been thanked: 8540 times
Glad you finally goy some sun, nice disks!
Thanks Warren!
Some of the closeups worked in Ha, taken with the double stacked coronado 90, 2x cemax barlow and zwo290mm camera.
Ar13100 Ha DS90 2x cemax zwo290mm bw by Mark Townley, on Flickr
AR13102 HaDS90 2x cemax zwo290mm-Recovered-Recovered by Mark Townley, on Flickr
departing plage Ha DS90 2x cemax zwo290mm bw by Mark Townley, on Flickr
Mark, the colored FD shots and closeup look very good indeed...well done
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
The hi res came out well Mark.
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 42 times
- Been thanked: 1487 times
Your DS90 closeups look in quite nice agreement with the SHG closeup I did on the same day: download/file.php?id=72579. I can see the etalon was better able to cope with the slightly non-deal seeing conditions. Any kind of rapid fluctuations will smear out the SHG images pretty effectively.
- Has thanked: 6181 times
- Been thanked: 7142 times
One month is a looong time. Good to see some images from you again! You managed to get very good results despite the seeing!
Arne
Arne
- nicspenceryork
- Has thanked: 5856 times
- Been thanked: 1257 times
- Been thanked: 4787 times
