AR3102 Calcium H September 17, 2022
- Has thanked: 9145 times
- Been thanked: 6025 times
Hello all: yesterday afternoon a session trying to capture detail of AR3102 in Calcium H. I used the TZ-4 and the FLIR 174 camera for this image. I also used the Apollo 432 camera, still trying to find out if anything good came of it.
- 142728 AR3102 color final.jpg (993.8 KiB) Viewed 712 times
- Been thanked: 10247 times
Re: AR3102 Calcium H September 17, 2022
Looks great Franco! My only comment would be to back off on the exposure a bit. Might be worth when weather and time permits running a set with the dial in differnt settings on the Quark, see what the outcome is.
Thank you, Mark, good advice. I will see what else I have in the data from Saturday.
- Has thanked: 6181 times
- Been thanked: 7142 times
Thank you David and Arne. This is different processing of the same image. Maybe better ?
- 142728 AR3102 color 2.jpg (232.78 KiB) Viewed 625 times
- Has thanked: 1640 times
- Been thanked: 878 times
I like the CaH images. Have you had a chance to evaluate your Apollo 432?
Thats a great re-work Franco!
- Has thanked: 8418 times
- Been thanked: 8163 times
Excellent, Franco. Nice rework. You’re really homing in on perfection.
- Been thanked: 8791 times
Thank you Alan, Mark, Stu, Alexandra and Starhugger: you are all very kind.
Alan: I have not completely figured out the Apollo camera yet. It seems to have great potential with the large pixels at high res but also has some limitations for me. 1) only 1.7Mp, there is a definite difference when compared with the 2.35 Mp of the FLIR174. It is about half price but the lower resolution is apparent in the results. I find sharpening Apollo camera images much harder then the 174's because of the lower resolution. 2) This is only Franco specific: I always forget to zoom out on Firecapture the subject of the image and end up having it in a corner. The chip is so large that to correctly position the subject you have to zoom out first, position the subject in the center and then zoom in and shoot. This is the only camera I have this issue with. A positive is that allows gamma, while the FLIR174 does not (at least mine does not in Firecapture). I am continuing to evaluate the camera while trying to learn how to use it best.
- Been thanked: 4787 times
I like them all Franco but the new processing show the fine details better.
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Great work Franco.
- Petrus
- Has thanked: 1496 times
- Been thanked: 684 times
Ah, every time I see your CaH images, Franco, I get the urge to get Daystar CaH Quark too! These are fantastic! Second processing shows those small bright areas better. Following with interest what results in you get with Apollo 432. It certainly has potential!
~ Petrus ~
Flickr
Flickr
Thank you Martin and SassySun for your wonderful support that keeps me motivated to improve my solar imaging.
- 143229 final color.jpg (1.03 MiB) Viewed 478 times
- Been thanked: 16694 times
Franco,
I actually quite like that first bright CaH image. It pops, it's vibrant!!
- nicspenceryork
- Has thanked: 5856 times
- Been thanked: 1257 times
They're brilliant Franco, great to see you having fun experimenting with it,
Nic
Nic
