simple SHG caK
highfnum
Has thanked: 57 times
Been thanked: 1205 times
simple SHG caK
Post by highfnum »
interesting prom lower right
Capture 2022-09-18T13_48_15_shift=0_clahesm-dns.jpg (237.62 KiB) Viewed 1260 times
Has thanked: 20834 times
Been thanked: 10503 times
Re: simple SHG caK
Nice result John!
highfnum
Re: simple SHG caK
Post by highfnum »
9 21 22
so sun rotated
Capture 2022-09-21T14_01_57ck_shift=0_clahej1s.jpg (251.73 KiB) Viewed 1215 times
Capture 2022-09-21T14_01_57ck_shift=0_protusj1s.jpg (93.27 KiB) Viewed 1215 times
Has thanked: 17974 times
Been thanked: 8907 times
Re: simple SHG caK
Wow!! these are some of your best, nice work :bow :bow :bow
fulvio.mete
Been thanked: 84 times
Re: simple SHG caK
Post by fulvio.mete »
Nice image, Highfnum
thesmiths
Has thanked: 47 times
Been thanked: 1527 times
Re: simple SHG caK
Post by thesmiths »
If you try stacking a few frames, you will get rid of some of the noise (for example, the jaggedness around the edge of the solar disk and the very bright regions). But make sure that you get the full disk in all the frames you stack. And the stacking program typically requires all the frames to have the same dimensions. Stacking even 5 frames will improve the noise a lot, because the typical noise is uncorrelated from frame to frame. Then you can use a sharpening program more effectively.
highfnum
Re: simple SHG caK
Post by highfnum »
thx all
very kind
I changed camera to asi290mm
also using solex-thesmiths software
i hope to stack soon
thesmiths SHG images are amazing and are as good as a filtergram or better
thesmiths
Re: simple SHG caK
Post by thesmiths »
highfnum wrote: Fri Sep 23, 2022 4:36 pm I changed camera to asi290mm
In my opinion, the best camera for this kind of imaging is the 178MM. Smaller pixels and larger sensor. It's available at a good price these days.
