Page 1 of 1
simple SHG caK
Posted: Sun Sep 18, 2022 7:13 pm
by highfnum
interesting prom lower right
- Capture 2022-09-18T13_48_15_shift=0_clahesm-dns.jpg (237.62 KiB) Viewed 1268 times
Re: simple SHG caK
Posted: Mon Sep 19, 2022 11:30 am
by marktownley
Nice result John!
Re: simple SHG caK
Posted: Wed Sep 21, 2022 9:32 pm
by highfnum
9 21 22
so sun rotated
- Capture 2022-09-21T14_01_57ck_shift=0_clahej1s.jpg (251.73 KiB) Viewed 1223 times
- Capture 2022-09-21T14_01_57ck_shift=0_protusj1s.jpg (93.27 KiB) Viewed 1223 times
Re: simple SHG caK
Posted: Thu Sep 22, 2022 6:56 pm
by Montana
Wow!! these are some of your best, nice work
Re: simple SHG caK
Posted: Thu Sep 22, 2022 7:44 pm
by fulvio.mete
Nice image, Highfnum
Re: simple SHG caK
Posted: Fri Sep 23, 2022 12:09 pm
by thesmiths
If you try stacking a few frames, you will get rid of some of the noise (for example, the jaggedness around the edge of the solar disk and the very bright regions). But make sure that you get the full disk in all the frames you stack. And the stacking program typically requires all the frames to have the same dimensions. Stacking even 5 frames will improve the noise a lot, because the typical noise is uncorrelated from frame to frame. Then you can use a sharpening program more effectively.
Re: simple SHG caK
Posted: Fri Sep 23, 2022 4:36 pm
by highfnum
thx all
very kind
I changed camera to asi290mm
also using solex-thesmiths software
i hope to stack soon
thesmiths SHG images are amazing and are as good as a filtergram or better
Re: simple SHG caK
Posted: Fri Sep 23, 2022 6:45 pm
by thesmiths
highfnum wrote: ↑Fri Sep 23, 2022 4:36 pm
In my opinion, the best camera for this kind of imaging is the 178MM. Smaller pixels and larger sensor. It's available at a good price these days.
