Just seen this over on CN forum , poster was skeptical , as am I ...
https://spaceweathergallery.com/indiv_u ... _id=188540
Flare with white light and 12nm Ha ... ? Thoughts.
- steveward53
- Has thanked: 1238 times
- Been thanked: 1497 times
Steve.
Day by day Solar album ... http://www.astrobin.com/users/steveward53/
Tal 100RS , ED80Pro , Mak180Pro.
HEQ5Pro , EQ3/2 , 14' pier.
Canon 1000D , SPC900NC Mono.
Scopium wedge - Baader ND3.8.
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: Flare with white light and 12nm Ha ... ? Thoughts.
A stacking artefact more likely...
- steveward53
Reply from Marty Wise on CN ...
"You can capture proms with wider bandpass filter systems. There's nothing behind them (space) that is brighter (ie, no photosphere)."
"You can see them with no filter at all, during an eclipse, because the disc is masked and there's nothing behind the prom."
if you're on here Marty could you elaborate please ... ?
Steve.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Steve, are you aware of the Carrington event? https://en.wikipedia.org/wiki/Carrington_Event I caught that flare in H alpha It was bright.
- steveward53
You're doing well to still be typing if you caught the Carrington Event ...Martin_S wrote: ↑Mon Sep 19, 2022 12:27 pm Steve, are you aware of the Carrington event? https://en.wikipedia.org/wiki/Carrington_Event I caught that flare in H alpha It was bright.H-alpha_105531_lapl4_ap738sc.jpgScreenshot 2022-09-19 223037.jpg
Steve.
- Martin_S
Hmm yes , I need to improve my English grammarsteveward53 wrote: ↑Mon Sep 19, 2022 12:40 pmYou're doing well to still be typing if you caught the Carrington Event ...Martin_S wrote: ↑Mon Sep 19, 2022 12:27 pm Steve, are you aware of the Carrington event? https://en.wikipedia.org/wiki/Carrington_Event I caught that flare in H alpha It was bright.H-alpha_105531_lapl4_ap738sc.jpgScreenshot 2022-09-19 223037.jpg
- Been thanked: 2725 times
So, Martin confirmed we had a small bright surge visible with a "narrowband" 12 nm Ha filtre.
Very interesting.
The Sun is full of surprise !
Very interesting.
Indeed. I eat my words!christian viladrich wrote: ↑Mon Sep 19, 2022 1:22 pm So, Martin confirmed we had a small bright surge visible with a "narrowband" 12 nm Ha filtre.
Very interesting.
- Has thanked: 17845 times
- Been thanked: 16977 times
It probably would be possible in an off band Ha filter tuned high which shows more photosphere.
In a 12nm wide Ha filter it would indeed be a surprise. That was an intense one!! Martin's image shows some double limb and chromosphere too.
- steveward53
Martin's image is from a Hydrogen-alpha rig not a "white-light + 12nm Ha" set-up ...DeepSolar64 wrote: ↑Mon Sep 19, 2022 2:36 pm It probably would be possible in an off band Ha filter tuned high which shows more photosphere.
viewtopic.php?t=38110
His chromosphere image from the same time is just confirming that there was indeed a flare and prominence there at the time ...
Steve.
