September 20 2022 Visual and Imaging session. A struggle!
- Has thanked: 17581 times
- Been thanked: 16697 times
Today I started the session around 14:50 intending to do visual only. I noticed the active regions coming through really bright in the Coronado 60 and the tuning looked good in doublestack. I thought I would try to get a good pic of it and went in to get my other mount, camera and laptop. Upon re-setting up, refocusing and everything I found out quickly that it did not look good in the monitor. The etalons were off band and the disc was unevenly illuminated. No matter how much I tried I never could get it to look like that earlier visual view. I don't know if I knocked off the tuning when I remounted the scope or what. Imaging seems to be harder for me to get onto band than visual, especially in doublestack. With visual if you don't get it perfect you can at least use the on-band portion of the field of view to see everything by moving the sun around in the field onto the on-band part to see fine detail. With imaging for it to look right it must be on band AND evenly illuminated across the disc to get a pleasing view. Imaging is VERY unforgiving and more demanding of the scope too. I sometimes find it very frustrating in DS to get on band and I can always tune better by the eyepiece it seems. And then when I was just starting to get somewhere clouds show up. I said " I'm done " and ended the session without a detailed visual report at around 15:40 UTC. I used the Coronado SolarMax II 60 today and the Orion70. The temperature is 79F. The seeing was decent.
I'll post a GONG and SDO image to show what's going on. AND my not so good single Ha image.
- Been thanked: 4787 times
Re: September 20 2022 Visual and Imaging session. A struggle!
Lovely report James and beautiful images too.
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
James, here's a few tips for you to assist with tuning. Could you get someone to tune your etalon for you while you concentrate on your monitor?. I use firecapture and set my onscreen view with the gamma set to show a view with lots of contrast to exaggerate tuning deficiencies. If you cant get a decent full disk, get a low powered nose Barlow and magnify your image so the sweet spot fills the whole frame, then do mosaics for your full disk images. I had to do this with my Lunt60. I also machined down some nosepieces to give just the right amount of magnification.
Martin
Martin
Thanks for the suggestions Martin. Both are good ideas. I could get my wife if she’s not at work to help me tune as I watch the monitor and the idea with the barlow is good too. Is your Lunt 60 a tilt tuned model or a pressure tuned one?
- Been thanked: 8793 times
This is very good advice Martin or James you can turn your laptop screen to face you while you stand at the etalon end. This it what I do and stand and twiddle by watching the screen.
Start with single first and get it right on screen, then add the double, you may have to not put the double stack on all the way, sometimes 180 degrees or 90 degrees from tight will give you a better even spread of 'on band'. But be careful it is screwed on enough that it doesn't drop off!
Good ideas Alexandra! Is turning the etalon in that way the same thing as " clocking " it?
- Sumpy
- Has thanked: 324 times
- Been thanked: 388 times
I've never double stacked so I can only imagine how challenging it must be to get two etalons cooperating and on band perfectly for imaging.
I think we've all had a day like this, though. I've had things looking great, changed something, and then never was able to get things back the way it was before. The other day I grabbed an image on the alt/az mount, and afterwards decided to try another timelapse on the eq mount. For some reason, I never could get the full disk on band with the eq mount, even though the entire disk was on-band with the alt/az mount minutes earlier, and I have no idea why. I tried again the next day and had no issues at all, so I just chalked it up to one of those odd things that happen occasionally.
- Martin_S
James, I sold my Lunt and replaced it with a Combo Quark as I am more interested in high resolution imaging.DeepSolar64 wrote: ↑Wed Sep 21, 2022 2:00 pm Thanks for the suggestions Martin. Both are good ideas. I could get my wife if she’s not at work to help me tune as I watch the monitor and the idea with the barlow is good too. Is your Lunt 60 a tilt tuned model or a pressure tuned one?
The Lunt was a tilt model.
Martin
It can be really frustrating, Brian. Fooling around with tuning while following the sun manually while learning new software and then you have clouds. And I am more familiar with eyepiece views.
I will persevere on....
- Been thanked: 10248 times
Lots of good advice here James, you will get there.
I really get frustrated sometimes. Most people here post images better than mine and I would at least like to get mine to a fair standard. It's a goal I guess.
Thanks Mark.
