Today I tried my first attempt at a solar scan in Ha using my Lhires III with 15um slit and 2400l/mm grating on a 120mm f/5 achromat stopped down to 60mm f/10. Because of the glass mirror slit I placed a Baader ERF over the objective limiting me to the Ha wavelength (have a neutral density filter on order) so as not to break the glass,used 3x rate on the handset of the CEM60 to force the scan (and beat the clouds). After using Solex reconstruction software I used Astrosurface to sharpen and rotate to correct orientation,still got plenty to learn
Alun
First attempt at solar scan 21st Sept 22
- Alun_H
- Has thanked: 648 times
- Been thanked: 621 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 17533 times
- Been thanked: 8763 times
- Has thanked: 42 times
- Been thanked: 1485 times
Re: First attempt at solar scan 21st Sept 22
That looks very good, especially for a first attempt. Are the dark areas due to clouds? Was it not possible to scan faster because of the exposure time? I don't think you need both the ERF and an ND filter. Which reconstruction software did you use?
- Alun_H
Thank you Alexandra,Douglas for the kind comments,also the SPOD totally unexpected
Douglas,I used the ERF for today's session but have the ND filter on order so as to replace it since I will want to image in the other wavelengths,I used an exposure time of 0.1873ms in Sharpcap with the QHY5III 178M (using ROI 3056x304) and just used the speed of x3 as a starting point which gave me an SER file of 3085 frames and 5 gig in size,but how fast is too fast before blurring/smudging of the detail in the images occurs? The darkening of the east limb is due to vignetting in the spectroscope the other areas are as you say clouds that drifted through. For reconstruction I used your software package,I did try Valerie's INTI but it kept crashing whereas yours is much more stable
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
In general, I would try to scan as fast as possible. Your exposure time is extremely short; is perhaps your gain too high? In general, I try to use gain close to zero. You might also try to use a narrower ROI (below 200). That will increase the FPS. The exposure time obviously needs to be faster than 1/FPS. Not many first attempts look that good!
- Alun_H
Thank you,my gain was at a setting of 22 in Sharpcap so next attempt I will do as you suggest and use zero. I set the ROI to make allowance for the curvature of the Ha line,image below,which is typical of the Littrow design.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
You could definitely make the ROI narrower -- that's really not that much curvature. Your camera is a little tilted with respect to the diffraction grating; if you correct that, you would need to also rotate the slit slightly.
The video is also quite a bit underexposed. The little line just underneath the H-alpha line should be just barely visible (then the exposure will be about right).
You might also consider attempting to clean the slit a bit. But I would consult the manufacturers instructions on how to do this.
- Alun_H
Thank you for the tips,I can rotate the camera to sort the tilt,must have knocked it when I had to catch the spectroscope when it nearly crashed to the floor whilst setting up,thought I'd tightened the focuser lock screws enough Doh! The slit on the other hand cannot be adjusted in the Lhires,it is a square piece of glass with four slits engraved around its edges and it sits in a metal holder with no means of adjustment. As to cleaning I had a go at doing so following instructions from Shelyak but to no avail,I do have another plate that I have set up for my night observations of Be stars,once I know that the heat won't damage the glass I can swap over as these are not cheap at 188 quid a throw
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 20240 times
- Been thanked: 10116 times
Very impressive indeed!
- Alun_H
Thank you Mark.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
