Today I tried my first attempt at a solar scan in Ha using my Lhires III with 15um slit and 2400l/mm grating on a 120mm f/5 achromat stopped down to 60mm f/10. Because of the glass mirror slit I placed a Baader ERF over the objective limiting me to the Ha wavelength (have a neutral density filter on order) so as not to break the glass,used 3x rate on the handset of the CEM60 to force the scan (and beat the clouds). After using Solex reconstruction software I used Astrosurface to sharpen and rotate to correct orientation,still got plenty to learn
Alun
First attempt at solar scan 21st Sept 22
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 17970 times
- Been thanked: 8905 times
- Has thanked: 1640 times
- Been thanked: 878 times
- Alun_H
Re: First attempt at solar scan 21st Sept 22
Thank you both Alexandra,Alan for the kind comments.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
