Observations 10.50 BST 23/09/2022 Proms
AndiesHandyHandies
Has thanked: 3304 times
Been thanked: 1902 times
Post by AndiesHandyHandies »
Sunny, high haze, still
90mm TS Triplet F6.7, 2" 40nm, T2 Baader Prism, Energy dump & 20mm baffle in T2 Pass-28.5mm,
9mm baffle on 4.2x, Chromo, 20mm baffle on 1.25" Helical focuser,
20mm baffle on polariser on 32mm Meade SP 4000 with added 20mm field stop.
10.50 BST
Max Chromo setting clockwise
7.30 Three expanding sprays leaning with faint pyramid under.
8.30 small spray, little curve prom towards, small gap and bright tiny spike. Fuzzy dumpy prom.
9.15 Active region
10.00 Very faint dumpy prom
? Small spike
2.45 Little seperated blob. Expanding spray. Two smaller faint sprays. Little faint pyramid.
3.45 Little spike. Faint dumpy. Faint double height, lower left and higher right.
4.00 Little spike leaning up.
Cheers. Andrew.
Has thanked: 17924 times
Been thanked: 8889 times
Re: Observations 10.50 BST 23/09/2022 Proms
Sounds like a lovely solar session :hamster: looks like it is nice and sunny outside, we had thick fog earlier this morning.
AndiesHandyHandies
Through the gaps seen the active region send out spikes.
The prom at 3.45 really went off. First a big windblown tree then a Preying Mantis or Parakeet on a branch which blew off when clouds over. Little bar left over surface, Ten gallon hat over with a badge on the front leaning up to a pair of fuzzy arches in a pair of brackets with a bright spot between them at the bottom.
Have a look at Gong later or images tomorrow.
Cheers. Andrew.
Has thanked: 20738 times
Been thanked: 10436 times
Lovely report Andrew, thanks!
