Break in the clouds yesterday afternoon allowed me to attempt another Ha solar scan with the Lhires III with 15um slit and 2400l/mm grating,this time with the Evostar 72ED closed to 40mm f/10 and neutral density filter using x8 speed rate to force the scan.
Alun
False coloured
Ha solar scan 220923
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 18092 times
- Been thanked: 8934 times
Re: Ha solar scan 220923
Absolutely wonderful, well done
I would raise the gamma a bit as the contrast is very low and I think you are losing some black details.
- Has thanked: 20940 times
- Been thanked: 10587 times
Brilliant!
- Alun_H
Thank you Alexandra,Mark.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
