First light solar film white light
- Has thanked: 1680 times
- Been thanked: 1165 times
I think I will be breaking this out when I have excellent seeing conditions in the future.
C8 Baader solar film and with no Baader Continuum Filter (sold out everywhere), I grabbed a old orion green filter and and UV/IR cut off (better then nothing).
Any recommendations on max length of time for capture runs to avoid surface blurs at this focal length and greater?
Thanks
Rich
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
- Been thanked: 16693 times
Re: First light solar film white light
Rich,
The green filters work nearly as good as the Baader 540nm filters do. And I see granules!! What scope did you use?
DeepSolar64 wrote: ↑Sun Sep 25, 2022 2:43 am Rich,
Celestron C8, I will have to try a powermate with it.
Rich
A C8. Yep, that's enough aperture to easily do it! :-)
- Has thanked: 20424 times
- Been thanked: 10243 times
Good first light!
Surface blur won't be an issue unless the capture time is in the minutes. Seeing and exposure time are more likely to be the culprits.
- Been thanked: 4786 times
- Has thanked: 17667 times
- Been thanked: 8787 times
This is fabulous!!! well done I would try and back off in the sharpening though, I bet you reveal more fine detail if you use less sharpening
I have a tendency to do over sharpen, it's a bad habit and hard to break at times. I will try harder....
Rich
Thanks, just what I was looking for.marktownley wrote: ↑Sun Sep 25, 2022 6:23 am Good first light!
Thank you
Rich
