I had started out earlier with the dial at Max clockwise. 10.50 BST. Area in tune near control knob.
I worked back a click at a time.
+1 Click
12.05 PM BST
7.30 Spike prom at right, then twin branching prom, dot in between and another over.
8.30 Bright stubby prom then a broader diffuse one.
9.15 Active region. Bright area with little bump prom over.
3.45 Little bright left bracket, small gap, dumpy fuzz, striated with bar over the top and a spike over leaning up slightly and then bright spike.
+2 Clicks
12.30 BST
7.30 Floating dot. small spike leaning left slightly. Sperate dim spike off surface leaning right. Dim spike curving left with fuzzy dot over to right. Bright short spike to left by top of previous spike. Little dim comma below left. Broad fuzzy jet from surface.
12.50 BST
9.15 Active region. Bright spot plage. Bright spike prom, dimmer one below with spike from base leaning out, a gap, then more. All the same height. Gap then tiny bright spike.
12.55 BST
9.15 Active region. Bright spot plage. Bright spike over. Dim spike below from half way up and extending out a bit. Thin bright spike off surface leaning out below.
7.30 Bright spike. V shaped prom off the surface. Bright spike leaning to V at the top. Little floating fuzz. fuzzy hedge with fuzzy arch over leaning in. Couple of fuzzy areas to left of its base.
1.05 BST
9.15 Active region subsided.
+3 Clicks. Tuning area now bigger.
1.25 BST
7.30 Bendy bright spike. Bright floating thicker spike to left. The fuzzy prom by leaning left by it. Fuzzy prom under and left.
9.15 Active region. Short bright spike with dimmer twin forks at the top.
3.45 Fuzzy bifurcated low prom. Y prom brighter base. Fuzzy prom leaning down to bifurcated prom.
+4 Clicks
2.05 BST
8.30 Small filaprom.
+5 Clicks Tuning all over
3.45 A spreading tree with top blown up.
4.30 Small horizontally striped fuzzy prom leaning up. Square open prom with jagged top and two bright dots under.
2.30 BST
3.45 Fuzzy arch leaning up with jagged hair leaning up. Thin arch prom under continuing with 3 bright spikes over.
3.45 Then a Preying Mantis. Large bright prom. Fuzzy oval outline leaning up. Bright spike with heptagon over. Bright dot on left part and right part over them. Floating dot under top angle.
2.50 BST
3.45 Taken off. Bright bar over surface at the base. Outline of a ten gallon hat with badge leaning up to the right. Oval prom above that. Fuzzy dot at top with fuzzy arch below right with a little bar under it. Open oval under the left with a bright dot on bottom right between it and the fuzzy arch.
9.15 Active region Bright with small filaprom over.
3.07 BST I just push to the mount. Surprised to see the taken off prom some way off the surface. See my notes.
P1060875 by Andrew Huskinson, on Flickr
3.30pm BST
Sunny spells Clear. Light wind.
+6 Clicks The middle. More surface details light and dark. Active region good all over. See Montanas horse-shoes.
7.30 Spike with break in the middle. Above lower one fuzzy leaving up slightly. Upright fuzzy above with little straight arm above. Bright dot over surface with inverted V over. Fuzzy top knot. Feather jauntily leaning up. Small gap and thin arch prom with fuzzy arc leaning towards the inverted V.
8.30 Open square prom with spike out above, like a shovel. Fuzzy top side with little fuzzy extrusion up.
2.45 Floating fuzz ball. Y shaped prom. Three spikes spreading a bit. Small pyramid with fuzzy blob over top side. Floating flat blob over.
3.45 Bull rush top (Seen some on walk today) leaning down and then a short thin spike leaning up. little gap and an exclamation mark leaning up.
4.40pm BST
Middle +1 Proms a bit sketchier? Plages brighter. Magnetic lines? Active region - man with dark tonsure hair, pointing to the right with sword in other hand pointing down.
Middle +2
Middle +3
Middle +4
5.03pm BST Active region a ski jumper with prominence as skis.
Try middle +1 as a start next time.
Cheers. Andrew.
My notes. Rough sketches as aid de memory.
P1060878 V01 by Andrew Huskinson, on Flickr
P1060877 V01 by Andrew Huskinson, on Flickr
More Observations 23/09/2022
- Has thanked: 3317 times
- Been thanked: 1907 times
Last edited by AndiesHandyHandies on Sun Sep 25, 2022 5:59 pm, edited 1 time in total.
Re: More Observations 23/09/2022
Fabulous session and details Andrew, I really love to see your notes and sketches
- Been thanked: 10488 times
A great report thanks Andrew!
