H-alpha, H-beta and Ca-K SHG images from Sept 25
thesmiths
Has thanked: 47 times
Been thanked: 1521 times
Post by thesmiths »
The imaging window is getting really short for me now. With the Sun so low here in London, there is only a short time when there is no obstruction from trees and buildings . Unfortunately, SHG imaging is slow and when time is of the essence, choices need to be made. So today I decided to get three wavelengths in one fairly short Sunday morning session. Normally I take two or three series of scans for each wavelength to get things like the focus and exposure just right. Today, I just did one series per wavelength to try to get them all in. The H-beta turned out well; the H-alpha could have used a bit more work; and the Ca-K was a bit overexposed (some highlights were saturated). Nevertheless, it's nice to be able to compare features in all three wavelengths. Click on the images to see at higher resolution.
H-alpha SHG image. Crop from full disk, inverted. Stacked 13 of 18 frames. 8:17 UTC to 8:24 UTC.
H-beta SHG image. Crop from full disk image. Stacked 8 of 14 frames. 9:17 UTC to 9:25 UTC.
Ca-K SHG image. Crop from full disk image. Stacked 15 of 21 frames. 10:29 UTC to 10:41 UTC.
H-beta, Ca-K, H-alpha full disk mosaic.
All images were taken the morning of 25 September. The break between the H-alpha and H-beta images is the normal time it takes to adjust the setup for a new wavelength. The time between the H-beta and Ca-K also included a pause due to clouds.
720mm APO triplet refractor. 106mm aperture for H-alpha and H-beta, 72mm for Ca-K. ASI 183MM camera. 13x sidereal rate scan for H-alpha and H-beta, 11x scan for Ca-K. 2400 l/mm holographic grating, 50mm x 50mm. 135mm f3.5 collimator and camera lenses. 9 micron wide by 12 mm long chrome on fused quartz slit. 2-inch Astronomik L1 UV/IR filter 15 cm in front of the slit. HEQ5 Pro mount with EQMod. FireCapture, AS!3, ImPPG, Photoshop Elements.
Alun_H
Has thanked: 648 times
Been thanked: 622 times
Re: H-alpha, H-beta and Ca-K SHG images from Sept 25
Post by Alun_H »
Superb images Douglas.
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Then there is all the night kit which is far too long a list to write up here! :lol:
Has thanked: 17888 times
Been thanked: 8887 times
This is such a fine trio :bow :bow :hamster: I find the hydrogen beta very absorbing to ponder over.
thesmiths
Post by thesmiths »
Montana wrote: Sun Sep 25, 2022 6:33 pm I find the hydrogen beta very absorbing to ponder over.
I know what you mean. It's kind of a familiar face and yet a bit inscrutable.
Bastelhannes
Has thanked: 83 times
Been thanked: 138 times
Post by Bastelhannes »
[/quote]
[/quote]
the feeling i have every morning looking into the mirror...
thesmiths
Post by thesmiths »
As a little experiment, I took the Calcium K data and applied a pixel shift of +4 and stacked the best 6 frames. This is therefore a slightly off-band image, although still very narrow band. The results are the following:
CaK, pixel shifted by _4, stack of 6
The contrast becomes much less: the filaments essentially disappear and the prominences are much less visible. I think it is worth comparing this off-band image to a standard Lunt CaK image (taken by Pedro on the same day):
Wow!! absolutely fabulous :hamster: so, the holy grail, how do we get our Lunt wedges to be more on the centreline (narrower) :)
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
Absolutely superb SHG images. You really have set the standard very, very high. :bow :bow :bow
Has thanked: 20732 times
Been thanked: 10427 times
Fantastic results Douglas, a pleasure to see!
Montana wrote: Tue Sep 27, 2022 6:54 am how do we get our Lunt wedges to be more on the centreline (narrower) :)
Double stack and tilt tuning is the closest we will get to SHG results.
