AR13105 and AR13107 in Ha 28th September 2022
- Has thanked: 8559 times
- Been thanked: 8297 times
Limited time this morning with one thing or another, so I concentrated on the two closely associated active regions 13105 and 13107 using my 150 mm double stacked refractor.
The seeing conditions were reasonable, but not great, so I kept the exposures at 3 ms and added some gain to bring the brightness to acceptable levels to try to freeze out the turbulence. I used my usual Basler acA1920-155um camera, Genika Astro for image capture, AS!3 for stacking, ImPPG deconvolution/sharpening and PixInsight for finessing. Images are shown either as two pane or four pane mosaics to cover the necessary ground with my 2.5x PM.
20220928_Ha_AR13105 by Stuart Green, on Flickr
20220928_Ha_AR13107 by Stuart Green, on Flickr
20220928_Ha_AR13105_13107 by Stuart Green, on Flickr
Thanks for looking.
Thanks for looking.
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Re: AR13105 and AR13107 in Ha 28th September 2022
Fantastic images Stu.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- rigel123
- Has thanked: 8589 times
- Been thanked: 8822 times
Just love all of the subtle details inside the AR's, wonderful processing!
- EricF
- Has thanked: 1275 times
- Been thanked: 279 times
- Has thanked: 17860 times
- Been thanked: 17006 times
Nice hi-rez shots Stuart!!
- Has thanked: 9327 times
- Been thanked: 6163 times
These are excellent Stu. Love the contrast and detail.
Many thanks, everyone. I really appreciate your kind comments.
- Has thanked: 20828 times
- Been thanked: 10502 times
Nice captures Stu! Is the building work finished now?
- Been thanked: 4434 times
Really sharp results from the session Stuart...well done
Very nice series, Stu.
Thanks for sharing.
Thanks for sharing.
Many thanks, Mark, Brian and Valery.
Mark, yes, unfortunately the building work is still ongoing. Maybe it will be completed by the end of October. We can only hope.
Valery, I hope you're holding out okay there.
- Been thanked: 4881 times
- Has thanked: 4379 times
- Been thanked: 3977 times
Excelent work.
Thank you, Maurits and Pupak.
- Has thanked: 6305 times
- Been thanked: 7327 times
