One filaprom and two little proms 30 Sep 2022
BGazing
Has thanked: 289 times
Been thanked: 351 times
Post by BGazing »
There was a bit of Sun through cirrus cover, low at around 20-25 degrees and the limb was undulating in waves, so I expected bad numbers. I honestly just wanted to test FC and SSM trigger and was surprised by the good numbers SSM has actually shown. Could it be precisely because of the cirrus? Two days before I tested it on blustery sky after rain and it showed predictable 3-3.5 arcsecs, this time, I could set trigger at 1.5 and cutoff at 1.9 for 3000 frames. It sorta worked...I left it at f/14, so critical sampling.
Seeing figures, to my surprise
Seeing values=0.64-1.95; Average 1.22
Seeing values=0.78-1.76; Average 1.29
Seeing values=0.85-1.90; Average 1.39
Could the numbers be low because of the cutoff? Average seeing figure was also quite good, not more than 1.7...which would be maximum resolution for my 80mm, it is just that I sample 3 pixels on that figure, but the resolution is an objective cap.
If someone knows about the quirks of SSM numbers, would love to hear. Bonus question...how do I smooth that magnetic lasso thing at the end?
Anyway, here are the shots, cirrus spoiled the disk details so I went for vignettes.
2022-09-30-0658_3-u-l-lunt_exposure=3.6ms_gain=0_gamma=60(off)_close up_limit023820-023820_lapl4_ap1154 inv.png
2022-09-30-0658_3-u-l-lunt_exposure=3.6ms_gain=0_gamma=60(off)_close up_limit023820-023820_lapl4_ap1154 inv.png (412.83 KiB) Viewed 236 times
2022-09-30-0702_1-u-l-lunt_exposure=3.7ms_gain=0_gamma=60(off)_close up_limit023820-023820_lapl4_ap2266 inv.png
2022-09-30-0702_1-u-l-lunt_exposure=3.7ms_gain=0_gamma=60(off)_close up_limit023820-023820_lapl4_ap2266 inv.png (916.13 KiB) Viewed 236 times
2022-09-30-0654_2-u-l-lunt_exposure=3.5ms_gain=0_gamma=33(off)_close up_limit023820-023820_lapl4_ap2262 norm.png
2022-09-30-0654_2-u-l-lunt_exposure=3.5ms_gain=0_gamma=33(off)_close up_limit023820-023820_lapl4_ap2262 norm.png (2.44 MiB) Viewed 236 times
Lunt 80MT DS, 533/1600/462
Has thanked: 17807 times
Been thanked: 16941 times
Re: One filaprom and two little proms 30 Sep 2022
Post by DeepSolar64 »
Nice snake-like filaprom!!
Has thanked: 20738 times
Been thanked: 10428 times
Nice images and some good numbers with the seeing.
BGazing
Post by BGazing »
marktownley wrote: Sat Oct 01, 2022 5:39 am Nice images and some good numbers with the seeing.
Thank you...but the thing is...I am not sure how accurate the numbers are, i.e. how affected are they by a thin cloud cover...
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Nice to see.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
These came out well !
