October 4 2022 Imaging attempt :-(
- Been thanked: 16694 times
Today around 15:00 UTC I sat the SMII90 and C102 up for a bit of imaging on my back deck. It was a short time full of issues. Horrible seeing, lack of time for the Sun went behind trees before I got to everything, some clouds and tuning issues. Trying to rush through the session before losing the Sun to the trees and the seeing was the worst. All future sessions will take place at another location in the yard that has a longer period of sunlight. Winter is coming, that's for sure!! The Sun is MUCH lower than it was. The temperature was 62F ( 16.6C )
So frustrating. I also need to learn to stack in ASTRO IIDC. Stacking helps get by the seeing a bit. I never got to white light.
I'll post an earlier KSO Ha image to show where everything is on the disc.
Maybe next time....
Maybe next time....
Re: October 4 2022 Imaging attempt :-(
I certainly find visual MUCH easier to do!!StarHugger wrote: ↑Tue Oct 04, 2022 6:22 pm When proficiant solar imagers fill thier threads with good data consistantly both on this forum and others it really presents the illusion the process is more seemless than what it is.
Once we try it , the reality becomes more easily apparent.
Best of luck James...Plenty of missions Ahead.
Trees=^/=÷××3$>9?>_...err...
- Has thanked: 20438 times
- Been thanked: 10245 times
Glad you were able to get the bigger scopes out James! You got some good results for the season, it gets harder as we head towards winter.
- rigel123
- Has thanked: 8314 times
- Been thanked: 8540 times
Whichever way you most enjoy the sun is the path you should follow! Nice effort!
Thanks for your sympathy and support everyone. I certainly don’t see imaging replacing visual for me but I would like to get good enough to show what is clearly there. It’s certainly not easy and my visually oriented equipment ( mounts, etc ) doesn’t help either. But I don’t give up easily and I have done a few decent ones. And yes Alexandra I would like to get some clear sharp granulation shots!!
- Been thanked: 4786 times
- Has thanked: 8418 times
- Been thanked: 8162 times
Nice work, James. Your second image is more on band and shows the angry new active region really well.
FYI, my first images were worse than yours
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Hi James - we have all had sessions like that - imaging the sun is like fishing - enjoy the process & occasionally the outcome.
Maurits,
I already miss summer with it’s long days, high sun and surprisingly better seeing despite the heat. It won’t be long I will be dressing in heavy clothes to observe.
Stu,
Yeah the second one is more on band but fuzzy. The seeing was so bad focusing was even difficult.
Matt,
True that! And I love to fish!
Stu,
Matt,
- Been thanked: 4904 times
James:
Well you are doing what you like, the importance is to follow the Sun in the way one wants.
Thanks for your interesting reports.
Best regards.
Best regards.
So true that is, Eric :-) And you are very welcome.
