Hi All,
As it has been cloudy and rainy for a few days, and the sun is getting lower in the sky, I just took an hour to try out NAFE on today's GONG image from Learmonth, Australia at 07:21 hours UT from gong.nso.edu.
This is just a simple NAFE process, no sharpening or other processing (other than hiding noise). This is the 1st attempt using NAFE: parameter 0.15, and gamma 1. No ImPPG or stacking involved!
Hope you like it !
Magnus
Sun FD 6th Oct 2022 - GONG/NAFE process
- Has thanked: 9145 times
- Been thanked: 6026 times
Re: Sun FD 6th Oct 2022 - GONG/NAFE process
I like it Magnus but I am not familiar with the NAFE process…
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Franco,
NAFE is a software analyser for SDO AIA images. It seems to work to an extent for H-alpha. AZAstroguy on youtube demonstrated it in a recent tutorial. You can download NAFE. It works on 16 bit .tiff files which are in RGB, so you may need to convert 8 bit or mono images first. I think it is interesting.
http://www.zam.fme.vutbr.cz/~druck/Nafe/Index.htm
Magnus
- Been thanked: 10248 times
I've had a play round with Nafe before, presonally i'm not a fan I think it overcooks images.
- Been thanked: 8793 times
It has an unusual dotty appearance at close quarters but looks fine at a distance
- Been thanked: 4787 times
- Has thanked: 17581 times
- Been thanked: 16697 times
It’s Windows only probably….
I’ll try it out on the Slooh Ha images. They are rather noisy.
- Radon86
I agree it is designed for AIA.
I see a lot of noise so that needs more
attention.
Still I find it interesting and a quick type
of process.
Magnus
attention.
of process.
Magnus
Magnus,
Thanks for bringing this tool to our attention. I use the SDO data a lot!
