i can hear the chuckles
but I stacked 2 frames
and they seem to match pretty well
you gotta start at the beginning
my first SHG stack - caK yippe
- Has thanked: 57 times
- Been thanked: 1189 times
- Been thanked: 16689 times
Re: my first SHG stack - caK yippe
Hey, Thumbs up from me. You gotta start somewhere. I see CaK proms!!
The SHG has incredible potential. You can image practically any visible spectral line.
Congratulations on your first CaK double frame stack.
- Has thanked: 42 times
- Been thanked: 1487 times
You can image some non-visible lines as well (e.g. in the infrared).DeepSolar64 wrote: ↑Fri Oct 07, 2022 4:40 am The SHG has incredible potential. You can image practically any visible spectral line.
Awesome!! I bet some in UV too.thesmiths wrote: ↑Fri Oct 07, 2022 9:41 amYou can image some non-visible lines as well (e.g. in the infrared).DeepSolar64 wrote: ↑Fri Oct 07, 2022 4:40 am The SHG has incredible potential. You can image practically any visible spectral line.
- Has thanked: 17648 times
- Been thanked: 8787 times
Well done, this is pretty awesome just a tad over exposed in the bright plage but overall a big
I guess it's possible to go a bit further into the UV than Ca-K but I don't think much more. The sensitivity of the CMOS cameras starts to drop off quite rapidly. Even glass begins to get less transparent. On the other hand, the cameras are quite sensitive in the IR.
The atmosphere blocks extreme short wavelength UV light as well.
- Has thanked: 20424 times
- Been thanked: 10242 times
Stacking is the way forward!
