Advice on refractor for WL
- Oh, I get it now!
- Has thanked: 23 times
- Been thanked: 25 times
Hello,
I want to start making solar observations in white light with a solar wedge, I am going to buy one from Lunt in 1 1/4", I would like you to recommend a good refractor for this purpose, I don't know if it should have an ED lens or with a achromatic is enough for me, yes, I don't like to see CA in the image. I had some achromatic a while ago and for certain objects it was painful.Also looking advice for others accessories,like filters..
Well, thank you very much in advance.
a greeting
Fran.
a greeting
Fran.
- Has thanked: 20938 times
- Been thanked: 10587 times
Re: Advice on refractor for WL
Hi Fran,
If you're restricting yourself to a 1-1/4" wedge I would get no more than a 100mm frac. What sort of budget do you have in mind? What sort of mount do you have?
Hi Fran
I would recommend a Skywatcher ED80 then, see if you can pick one up second hand with an upgraded focuser.
- Has thanked: 17949 times
- Been thanked: 17093 times
If you use filters like a Baader continuum 540nm filter an achromat will do just fine. The filter will remove any CA present. Without a filter I prefer an achromat F8 or above to reduce chromatic aberration.
That's very fast focal length!
- Has thanked: 3096 times
- Been thanked: 2198 times
Such things exist?
I would recommend you a proper telescope with f/7 or more for this purpose of high magnification work on the sun. Certain scope abberations should be better controlled at this focal ratios.
Triband C9.25
H-a: 1-2 Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
I actually prefer F8 or longer. I do have a little 70mm F7.1 refractor that does well though even though it has some CA if white light is done without a filter like the Baader Continuum.
The CA is slight for the Orion70 but still there. It generally doesn't bother me. If I choose I can always use a filter like the Baader 540nm which increases the contrast of the spots and totally eliminates the chromatic abberation. Many people here use achromats for photosphere work but use filters at the eyepiece in addition to a wedge or over the aperture filter to boost detail and eliminate false color. I also have an apochromatic doublet with two ED glass elements that is false color free. My Astro-Tech AT72EDII which I use with the Altair wedge.
